Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 06-04-2010, 06:12 PM   #1
joosky
Member#: 240513
2006 WRX, stage 2
BLACK on BLACK
Default Less boost. higher atmospheric temp? COBB AP2
-alright I'm running 65% WGD and 14psi (compared to 17psi) through most of the power band. just started having rear 02 sensor CEL come on could this be my problem? or should i pull the stethoscope out and listen for knock? no other CEL's expt for secondary air injection which is smog pump and i am not worried about that. have been running this bad rear 02 for a month which i did not think made a diff cuz cobb ap is supposed to delete the cel for this cuz the wack reading w/a catless dp? or do i have no clue what i am talking about lmk thanks.
-is this higher humidity/heat making ecu cut boost to prevent pre-detonation? when it was 60 degrees or less out i was running easy 17psi not sure what the WGD was didn't log and building 10psi b4 launch. then as the average heat out here is now about 70-90 degrees w/ humidity upwards of 95%to 100% boost dropped to 14psi.
-haven't heard any noises other than normal tgv tic.
-02 sensor was bad still running 17psi did not psi drop till LC/FFS map update. went back to reg stage 2 no /LC+FFS still same 14psi.
-can make data logg if needed lmk thanks
-coolant 190-195 degrees
-not sure intake temp havent checked.
-ran car at track ran 14.2s@14psi compared to 13.5s@17psi
engine MODS LIST.
invidia catless DP w/nameless catback
cobb ap v2 stage 2 w/LC+FFS 93 octane
STI intake mani
perrin bov
sorry info is somewhat scattered
joosky is offline   Reply With Quote
Old 06-05-2010, 07:23 PM   #2
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
im literally experiencing the same problem . someone please help.
jerbull88 is offline   Reply With Quote
Old 06-06-2010, 01:55 PM   #3
joosky
Member#: 240513
2006 WRX, stage 2
BLACK on BLACK
looked at and logged knock learning and correction. gave me reading of -4.2 at worst only when i down-shift. no i have no i dea what that number is. im guessing its pulling timing -4.2? please any input would help thanks
Old 06-07-2010, 03:38 PM   #4
joosky
Member#: 240513
2006 WRX, stage 2
BLACK on BLACK
any one?
Would a bigger turbo w/ less boost be safer then a td04 with higher boost? pearl Newbies & FAQs 46 04-03-2009 12:16 PM
higher ambient temp = lower boost? tobylazur AccessPort 4 06-22-2008 12:27 AM
Cobb AP2 Live Data - Boost reading negative? colinwalsh AccessPort 6 03-17-2007 09:03 PM
Does cobb ap2 boost reading max at 18.4lbs? STI_SLC AccessPort 22 01-07-2007 11:47 PM
Less boost with more timing or More boost less timing? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2003 10:13 PM
