Old 06-05-2010, 01:34 PM   #1
sixthgearjunkie
Member#: 219497
1997 Impreza L
Default Strange noises causing potential problems!! help please!
so recently i have this new issue with my 97 impreza 2.2 l
whenever i start up the car i hear a squeaking noise like something rotating around and squeaking though this is usually only when i start up and every once in a while while it idles. I figure it is a belt as it sounds like it. And an even more pressing issue where every once in a while while im driving, the engine will "hiccup" and i will hear one of those squeaks only for a moment. i believe it is a belt, but does anyone else have any other ideas? if it is a belt can i replace it myself having little mechanical experience? i just took the thing out of the shop i can't afford for it to go back in.
sixthgearjunkie is offline   Reply With Quote
Old 06-05-2010, 07:02 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
start her up and pop the hood. listen for squeals. You can apply belt dressing if you like, but that's more like a band-aid. The proper thing to do is tighten the belt(s). Search on it in the maintenance forums, it's really easy to tighten. Just be sure to loosen the locking nut first.
Oh, and the fact that the engine hiccups during a squeak points me to the alternator/PS belt as the culprit.....unless you have the AC on at the time.
Old 06-05-2010, 10:46 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Not sure how either the alternator or PS would cause the engine to hiccup, as both of them are operating continuously. If this problem only happens periodically it's almost certainly the A/C kicking on, and the A/C compressor most definitely puts enough load on the engine to be able to feel it kick on.
Pat Olsen
Old 06-05-2010, 10:48 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yes, belt replacement is very simple. You'll just need 10mm and 12mm wrenches/sockets and you'll be good to go.
Old 07-04-2010, 05:36 PM   #5
sixthgearjunkie
Member#: 219497
1997 Impreza L
It was the A/C compressor belt! thanks!
So i clear my headlights... now strange problem! Help please! pics included! litowrx Electrical & Lighting 22 05-25-2009 07:10 PM
Cam potential, little help please Jpizzzle Built Motor Discussion 1 03-20-2008 11:58 AM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
Strange noise at 1500-3200 rpm.. please help!? theperfectK20 Service & Maintenance 0 12-11-2007 10:13 PM
Strange noise comming from engine bay...Please help UndertoW101 Warranty Issues & SOA Problems 13 11-21-2005 11:53 AM
