Old 07-07-2010, 10:36 AM   #101
SVT_WRX
Member#: 164830
G61 III OVE 58e
Just to give you an idea of how accurate the Airboy spreadsheet can be if used correctly:
Airboy results: 308/323
Went to a Mustangdyne chassis dyno three days later. My results: 308/323
I posted logs of that Airboy 308/323 run in my thread.
Yes, you can cheat with the spreadsheet. The same goes for tuners. They can cheat with their dyno's. Me personally, I probably will never go to a chassis dyno again. I made the Airboy/Trap speed thread for a reason. Once I get to the track, I will post what I made on the Airboy spreadsheet and post my trap speeds. Trap speeds are what really tells you how much you are making.
My personal goal is to have a reliable vehicle that will trap 118+. I personally won't be "happy" until that is accomplished.
SVT_WRX is offline   Reply With Quote
Old 07-07-2010, 09:06 PM   #102
SacksLax
Member#: 193949
You guys have ridiculous numbers for a 2.0. Yet mine is on 93, but 330+...good God. I guess trap speeds will tell all though. I'll airboy mine at some point, but I love this turbo and my car hauls ass now from 3700 till redline the torque is a table.
SacksLax is offline   Reply With Quote
Old 07-07-2010, 09:15 PM   #103
Clark Turner
Member#: 178047
02 WRX STI Spec C
And the best part is they seem to last and they are Dirt cheap.
C
Clark Turner is offline   Reply With Quote
Old 07-10-2010, 02:16 PM   #104
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Not sure yet...
4 CEL instances in 3 weeks so far...
GringoGomez is offline   Reply With Quote
Old 07-12-2010, 07:43 PM   #105
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Make that 6....
Six CEL's since new turbo & tune.....
Is this normal?
Old 07-12-2010, 08:01 PM   #106
JasonLHall
Member#: 111318
Originally Posted by GringoGomez View Post
Make that 6....
Is this normal?
nope not normal, what engine management and mods do you have?
JasonLHall is offline   Reply With Quote
Old 07-12-2010, 08:17 PM   #107
Clark Turner
Member#: 178047
02 WRX STI Spec C
Make that 6....
Is this normal?
Contact your tuner and tell him.. What codes are showing up?
C
Old 07-12-2010, 10:01 PM   #108
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Misfires in all cylinders, actuator low, and one other...
Old 07-12-2010, 10:16 PM   #109
Clark Turner
Member#: 178047
02 WRX STI Spec C
ouch..
C
Old 07-14-2010, 12:13 AM   #110
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Bad News..................
Old 07-14-2010, 12:26 PM   #111
JasonLHall
Member#: 111318
The cool tuner at the shop fixed it for free... It was some kind of sensor for the fuel injectors. He also checked my compression: 165, 165, 165, 170....
Car runs very smooth now. I am happy with the way things worked out!
glad to see things turned out well
Old 07-27-2010, 06:36 AM   #112
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
How did Verocious dyno-tune my car if their dyno was malfunctioning???
Old 07-25-2011, 06:54 PM   #113
BuGiReX21
Member#: 255606
2003 16GXT'd WRX
Hey guys I have an 03 WRX and this seems to be the turbo I want, as it seems to be one of the best turbos for the 2.0L. Right now im stage 2 tuned with AP and have a full invidia tbe and k&n short ram. Now its time to do turbo upgrade, and I am looking to making around the 300whp mark, maybe squeeze out a bit more. The only thing is I would like to see if its possible without meth and on just 93. Ive got the supporting mods STi TMIC ( I know a FMIC will squeeze out a bit more--- thats on its way) Warlboro fuel pump, and debating on whether to jump up to the deatschwerks 750cc injectors.
Anyone have any charts with a similar set up over the 300whp mark on 93 without meth, and if possible without a FM set up yet.
BuGiReX21 is offline   Reply With Quote
Old 12-28-2012, 02:15 AM   #114
Nickarub
Member#: 230509
06 vf39 wrx
ugm
Old thread but but I wanna see more of this turbo on some 2.5L
Nickarub is offline   Reply With Quote
Old 12-28-2012, 09:17 PM   #115
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
This Turbo is happier in a 2.0. Not impressive at all on the 2.5. Barely outshines the td04.
Black07STiGuy is offline   Reply With Quote
Old 12-28-2012, 11:03 PM   #116
Nickarub
Member#: 230509
06 vf39 wrx
ugm
Compared to a vf39? A worth upgrade? Most people I've heard make 240/260tq Ina td04 and closer to 300/320 on a evo3. A vf is under that around 280/290
Old 12-31-2012, 12:21 PM   #117
Nickarub
Member#: 230509
06 vf39 wrx
ugm
I will have a evo3 16g on my 06 Wrx soon. Then we shall see some new numbers.
Old 01-04-2013, 09:12 PM   #118
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
I made 330whp 311wtq on my evo 3 at 20psi on my 2.0l with 100k on if. Sellin it now going 30r
under0athh51189 is offline   Reply With Quote
Old 01-05-2013, 07:18 PM   #119
04psm
Member#: 153551
2004 WRX
psm
A few years back I had an evoIII16g on my 04 wrx it made 312whp/ 285tq. Tuned by Cleo at precision tuning on 93 pump. Loved it!!
04psm is offline   Reply With Quote
Old 12-25-2013, 10:14 PM   #120
OBP WRX
Member#: 330185
Here is the post from my 05 WRX with EVO III 16G...
http://forums.nasioc.com/forums/show....php?t=2538442
I did another set of road dynos (back to back) a few months later and one was 319/277 and the other was 291/256
I spun a rod bearing a few weeks ago so I will have new dyno plot in a month or 2...this time with a freshly rebuilt ej257 block with sti rods and manley forged pistons (99.75mm and 8.5:1 CR). The heads are being machined to 2.5L spec, 5 angle valve job, everything is being cleaned and built to spec. Also doing TGV delete and adding the 3mm phenolic spacers. Want to do an ELH header but don't have the money now so will have to add that later. Also need a new clutch, going with the Exedy stage 1 to try and preserve the stock 5 speed trans (adding blast plates to help as well). I am hoping for 320+ HP...but going to ask the tuner to keep the torque around 300 if possible until I can get a 6 speed. It will be tuned on 91, since you can't find 93 around here anymore and I don't have enough injector for E85 and the trans wouldn't handle it.
OBP WRX is offline   Reply With Quote
Old 05-11-2014, 11:22 AM   #121
GringoGomez
Member#: 33081
2003 Buggy WRHorse
Plain
Old thread... Got ripped off BIG TIME by Verocious. They were horribly abysmal in their work, service and professionalism. Had to get everything redone by a reputable tuner (CBRD in York, PA). CBRD did a good job and turn around time was days, not months. Ended up wasting $3,500 at Atrocious, I mean Verocious. Should have taken them to court...
Now I am getting ready for another tune. Hopefully there is something closer to home. I was looking at CBRD in York, Mr Evans in Easton and R/T in Lansdale. Does anyone have any experience with any of these tuners? I will NOT tolerate another Atrocious experience.
Old 11-05-2014, 12:11 PM   #122
KitchenerWRX
Member#: 79934
02 WRX
MBP
Reviving this thread as I wanted to share my 2.0L EVOIII-16g results before my motor build:
Car: 2002 WRX stock block w/ 140k miles
Mods:
Blouch EVOIII-16g
PE 650cc
eBay TMIC
Walbro 255lph
AEM 70mm CAI
Silicone inlet + After-MAF hose
Prodrive EBCS
Tial 38mm EWG VTA
HKS DP with Cobb (2.5" restricted) catback
Borla unequal header
TGV Deletes
On a mustang dyno, tuned by Neetronics in Oakville, Ontario, Canada I put down
308whp
292awtq
This was at 20psi, mildly aggressive timing and 11.2 AFR on 91-vpower
I really enjoyed the flat torque curve and peppiness of this turbo.
In fact I enjoyed it so much that on my fully built ej22t block I will be installing an EVOIII-16G and I believe this will be an ultimate killer DD weekend warrior setup
Stay tuned!
KitchenerWRX is offline   Reply With Quote
Poll: Shoulld All Posters To This Forum Be Obliged To Post Uncorrected Dyno Results ? macaws Proven Power Bragging 49 04-13-2008 12:16 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
Injen Posted dyno results for their CAI run on a 2004 WRX trustWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 73 01-24-2004 05:07 AM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
