Old 06-05-2010, 09:16 PM   #1
2.5guy
Member#: 226957
00 2.5RS Coupe
Default Coolant goes in reservoir but wont go back in rad!
Ok soo I am at a complete loss...
The 2006 2.5i motor was rebuilt with 2006 sti tri layer head gaskets
New timing belt
New water pump
New Thermostat
so my issue is after about 40 mins of driving keeping it below 3500rpm all the coolant will be over in the res and car will get hot. I pull over take the cap off pour the coolant back into the radiator and its good to go! I changed the Radiator cap and its still doing it..... Even once the motor and coolant cools down it does not suck coolant back into the radiator
If I run the motor at higher rpms it fills the reservoir back up faster
2.5guy is offline   Reply With Quote
Old 06-05-2010, 10:29 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
you still have a major head gasket problem, who did the replacement?
dstan is offline   Reply With Quote
Old 06-05-2010, 10:35 PM   #3
burton58
Member#: 115369
2002 WRX's
SRP & WRB, RIP to both
radiator plugged up? might need a flush
burton58 is offline   Reply With Quote
Old 06-06-2010, 02:30 AM   #4
2.5guy
Member#: 226957
00 2.5RS Coupe
I just found out if I run my heat on high it takes alot longer to fill the reservoir.... i'm going to check all the lines to and from the heater core to my rad and to the water pump.
I tried running it with the radiator cap off I did that for like 45 mins but the funnel I was using kept popping off
I tried a compression tester today on it but the loan a tool at advance's was broken wouldn't hold air......
Old 06-06-2010, 09:59 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Based on what you've described I would agree with dstan. Those are the symptoms I've seen on multiple occasions when I've had blown/leaky HGs on my car.
Old 06-06-2010, 11:49 AM   #6
2.5guy
Member#: 226957
00 2.5RS Coupe
I was hoping that wasn't the cause.... I will see if I can locate a compression tester see which head is giving me issues
Old 06-06-2010, 11:57 AM   #7
alloutSTI
Member#: 241552
2008 PB EVO X MR SSS
Phantom Black Pearl
what is your water/coolant mixture? 50/50?
alloutSTI is offline   Reply With Quote
Old 06-06-2010, 01:18 PM   #8
2.5guy
Member#: 226957
00 2.5RS Coupe
Yup 5050
Old 06-07-2010, 03:58 AM   #9
dcleal
Member#: 178135
2006 Impreza 2.5i
Did you bleed the cooling system after refill?
dcleal is offline   Reply With Quote
Bought a used subie, but wont go into gear? VIDEO INVLUDED! Bad_T Transmission (AT/MT) & Driveline 23 01-29-2010 11:03 AM
2008 wrx...Car goes in gear but wont move.... drunkon2canz Newbies & FAQs 14 10-12-2009 02:15 PM
trans wont go back in, please help wrx tekker Transmission (AT/MT) & Driveline 7 01-25-2009 04:14 PM
Up-pipe issue wont go back in! Chandy69 Factory 2.0L Turbo Powertrain 4 06-27-2004 09:28 PM
EMergency: STi engine mounts wont go back to the crossmember Sin Normally Aspirated Powertrain 9 06-19-2001 09:29 PM
Message Board Statistics All times are GMT -4. The time now is 03:26 PM.
