Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-06-2010, 04:12 AM   #1
pleiadi
Member#: 158257
2008 Impreza 2.0R
Newport Blue
Default Camber issue new Impreza 08
Hi All!
I measured the camber electronically and the rear got -1.48 on the right tyre and -2.02 on the left tire. Do you think that difference is ok? Wheels are alloy 16" and all is stock
Thanks
pleiadi is offline   Reply With Quote
Old 06-07-2010, 01:50 AM   #2
FLZ_Boy
Member#: 186303
2011 Legacy 2.5i 6MT
SPW
I remember mine to be around ~-1.0 for both the driver and passenger rear with the stock 2.5i suspension and 16" premium wheels.
FLZ_Boy is offline   Reply With Quote
Old 06-07-2010, 11:45 AM   #3
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Originally Posted by pleiadi View Post
Hi All!
Thanks
How were they measured? You can bring it to a dealer to have it checked. -2 is way too high and you want as close to 0 in the back as possible.
EtoS is offline   Reply With Quote
Old 06-07-2010, 02:25 PM   #4
pleiadi
Member#: 158257
2008 Impreza 2.0R
Newport Blue
Using this system http://www.hunter.com/pub/product/al...84-T/index.htm
The problem is that the rear right wheel got a hit and the shop replaced the upper arm (which is responsible for camber)...
That camber measurement was done after that replacement was done so they now ordered the 2 lower arms and the cast iron rounded thing that connects all arms to the wheel.
Old 06-24-2010, 07:21 PM   #5
scoobyoutback73
Member#: 116512
1999 impreza sport
wow. there is no upper arm. its a strut that adjust the camber. the lower arm adjusts the toe. hopefully they measure the alignment by hooking the heads to the rims and not the tire, because that will mess things up. get a 20$ adjustable cam bolt, and it will bring the camber out to decrease the negative camber. easy fix.
sounds like there a body shop. they love replacing everything with new parts. lots of money to do that! unless insurance is paying for it!
scoobyoutback73 is offline   Reply With Quote
Old 07-03-2010, 09:04 PM   #6
5.0Ranger
Member#: 93546
08 wrx
pearl white
on the 08 and up yes there is a upper arm in the back. I would say the lower might have got bent too.
5.0Ranger is offline   Reply With Quote
Old 07-04-2010, 07:32 PM   #7
cmiovino
Member#: 134005
2004 WRX Premium
I've heard to run max negative in the front.
I can attest to this as on both my previous Imprezas, the tires wear the most on the outsides of the fronts, even if you keep it at stock alignment specs. Max negative camber, could combat this, as toe is already good at stock.
*SERIOUS* LACK OF -camber issues. Even with camber plates only get -1.8*? pics modaddict Brakes, Steering & Suspension 67 04-01-2013 01:02 PM
Fs(nj) Weathertech Digitalfit Floorliners Impreza 08+ New $119 michael_lombardo Interior/Dressup/Audio & Security 0 02-03-2010 04:11 PM
coilover issue...and neg camber issue cknowlen Brakes, Steering & Suspension 2 09-18-2009 08:09 PM
FS VA - brand new Whiteline rear camber kit '08+ Impreza PGT Suspension/Brakes/Handling 2 06-05-2009 10:26 AM
A'Pexi N1 TypeV + WRX Wagon - Front camber issues? Macabre Brakes, Steering & Suspension 9 01-23-2004 08:40 PM
