Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 06-07-2010, 06:29 PM   #1
V8Nate
Member#: 215703
2003 WRX
Default 04 sti longblock in 03 WRX no AVCS
I have a 04 STI longblock that I was going to use to build a hybrid but now I am confused. Can I use the STI longblock with my wrx manifold, tgv's, and throttle body and just not hook up the AVCS and it will work or will I still need to convert the ECU and harnesses or do something else to get it to work. I tried to search for it but everything I found was for keeping the AVCS.
V8Nate is offline   Reply With Quote
Old 06-07-2010, 08:07 PM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Yes it all bolts up ( physically ) more or less.
The AVCS will not function unless you wire it in and have the STi ECU. If you dont the AVCS will fall to "default position" and be basically inactive. I have spoken to numerous Suby techs about this and their theory has varied in all their explanations....some say low cam position is default others mid and others have no idea. Either way it will run just not as well as active.
I assume you know you will need a re-tune no matter what due to different compression ratio and .5L increase in displacement.
dangerousatom is offline   Reply With Quote
Old 06-07-2010, 08:21 PM   #3
V8Nate
Member#: 215703
2003 WRX
I understand I will need the re-tune which is fine because right now I am running the cobb ap and I am looking to get rid of it. I've been doing some more research and now im trying to figure out if I should use the avcs cam gears or use the wrx non avcs cam gears and plug up the holes in the cams.
Old 06-09-2010, 12:30 PM   #4
sense of nature
Member#: 112759
?? pending....
sale....
I would plug the holes & run the Wrx cam gears .. they are lighter .. less rotating mass
sense of nature is offline   Reply With Quote
Old 06-09-2010, 04:49 PM   #5
V8Nate
Member#: 215703
2003 WRX
Makes sense. I think ill be doing that unless I decide to run the WRX heads and then ill be throwing the STI cams in them.
Old 06-09-2010, 11:19 PM   #6
sense of nature
Member#: 112759
?? pending....
sale....
You would still need to plug the holes
Old 06-09-2010, 11:32 PM   #7
V8Nate
Member#: 215703
2003 WRX
Yeah, I know I will need to either way. Just trying to figure out which will perform better. I can't find much on comparison between a hybrid and the sti longblock without running AVCS
Old 06-09-2010, 11:50 PM   #8
dangerousatom
Member#: 70710
call www.metricmotorsxtreme.com in they make sand rails out of suby motors. The tech guy I spoke to is a suby genius to say the least. He gave me excellent advice and insight on my Legacy 2.2 turbo build with 2.5i SOHC heads.
Old 06-11-2010, 05:09 PM   #9
sense of nature
Member#: 112759
?? pending....
sale....
I've done both & IMO the hybrid was more fun to drive off boost .. way more torque down low ,I was still running 19 psi on my vf39 too
Old 06-13-2010, 04:53 PM   #10
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
ive got an 05 sti lb in my 04wrx with ej20 ecu and harness... Never plugged the cams or used avcs. Made 407whp with a 35r and the car runs great... My tune is open source. It has been the setup on my car for about a year now. Only thing i had to get was a cam angle sensor bracket from cosworth because the 05sti lb has the sensor in the front of the head instead of the rear like some other years.
srREXed is offline   Reply With Quote
04 STI cluster in 03 WRX but no cruise control light Fierysun Electrical & Lighting 2 04-21-2010 10:39 AM
04 STI gauge in 03 WRX- gas level problem TommyWRX Electrical & Lighting 3 02-02-2008 05:43 AM
STi longblock in 2002 WRX WickedRydaX Subaru Conversions 10 02-12-2006 09:41 PM
04 STI suspension in 03 wrx tux Brakes, Steering & Suspension 3 04-19-2005 03:22 PM
04 USDM STI cluster in 03 WRX? Equilibrium Tuning Interior & Exterior Modification 4 06-22-2003 08:34 AM
