Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-08-2010, 01:09 AM   #1
cmiovino
Member#: 134005
2004 WRX Premium
Default What's leaking here?
'98 EJ22E 90K miles
I noticed something leaking a good bit today underneath the engine. I think it's possibly the rear main seal. The first pic shows a good amount of oil coming from the rear of the engine where it meets the transmission. It drips down to the headers and on the floor a little. The car has been sitting about a week. The second and third pictures show some wetness in the area of the headgaskets, but I don't think it's from that. It's not bad at all compared to the wetness on the first pic.
Sooooo, from my bad pictures, any idea what's wrong or should be alarmed? I'm getting the timing belt replaced ASAP since it's due by a shop (interference engine, not messing with it).... unrelated info, but if anything else needs done, it's the time to do it.
Passenger side:
Driver side:
Old 06-09-2010, 09:43 AM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
It may be the breather that is behind the passenger intake runners. It has a thick rubber pipe that leads to your pcv. I had a bad leak on my 98 RS EJ25D motor and that fixed it. The rubber hose was cracked.
Gr3en is offline   Reply With Quote
Old 06-09-2010, 02:27 PM   #3
Tessai
Member#: 214184
1999 Legacy Outback
The underside of my EJ25-equipped car looks like that, I've got a leak on the driver's side of the oil pan.
Tessai is offline   Reply With Quote
Old 06-10-2010, 02:12 AM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Start with valve cover gaskets and go from there. They are the easiest and do wear out over time.
PhilSine is offline   Reply With Quote
Old 09-20-2010, 05:32 PM   #5
cmiovino
Member#: 134005
2004 WRX Premium
Just to give a little update (even though it's been like the whole summer)... it was the CV joint and it was grease not oil. I'm a noob
But yeah, learned a thing or two while changing it, and what to look for with commonly torn boots.
Old 09-20-2010, 05:48 PM   #6
RaineMan
Member#: 256727
2007 2.5I Wagon
Well, glad it wasn't anything major! Any time I see leaks or puddles under a car I think "Oh crap."
RaineMan is offline   Reply With Quote
Has anyone had an a/c leak here? jeff1872t Service & Maintenance 10 05-28-2009 04:28 AM
What's leaking? Scoobie Noobie Service & Maintenance 6 02-22-2006 10:26 AM
Corvette review in todays' paper. What's wrong here? SubEd Off-Topic 20 05-07-2004 03:49 PM
CAN - Controller Area Network...What's happening here? QA Guy Engine Management & Tuning 5 08-12-2003 08:29 AM
Do you know what's wrong here? booger Warranty Issues & SOA Problems 7 04-21-2002 03:17 AM
