Old 06-08-2010, 09:00 AM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default Help, my car stays in open loop
So my 98 Legacy GT 2.5 wagon will not go into closed loop. I am also getting a P0130 code for the O2 sensor sensor bank 1 sensor 1 malfunction.
I have replaced the sensor 3 times with new units. The wires going to the ECU from the sensor all have continuity, and the ground wire is good as well. I have checked all the values on both sides of the sensor connector backprobing it. The heater wire has 12V and the ref wire is 1.5V with the sensor unplugged. Running (at idle) the sensor is around .6V.
When I give it some gas and hold steady (around 2500rpms) both O2 sensors zero out and stay there.
I know your coolant temp sensor helps to control open/closed loop operation. When I attach a scanner the coolant temp seems pretty accurate and operating temps are around 190-200. Could my temp sensor be failing, I dont recall the correct operating temp? I need help with this one. I know someone has to something about this problem or could help me t-shoot this. I dont want to take it to the dealer because I like to do things myself.
Thanks for any help.
iluvdrt is offline   Reply With Quote
Old 06-08-2010, 10:10 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
190-200F is just fine for the coolant temp, so that seems normal.
If you haven't already done so, I would post this in the Engine Management forum or maybe Service & Maintenance to try to get some more exposure. This isn't a Legacy issue, so posting it in the Legacy forum just means a smaller audience has a chance to see this.
Pat Olsen
Old 06-08-2010, 05:41 PM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
will do, thanks Pat.
Old 06-10-2010, 01:45 PM   #4
ben g
Member#: 227843
Check your pcm
ben g is offline   Reply With Quote
Old 06-10-2010, 05:46 PM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
Originally Posted by ben g View Post
Check your pcm
Anyway how?? My scanner hooks up to it and pulls live data and reads codes. I don't know how to check it much more then that.
Old 07-06-2011, 12:24 AM   #6
dreadedwaygone
Member#: 149819
64 mustang
real cars are red
any luck?
Im having the same problem..P0130 code for the O2 sensor sensor bank 1 sensor 1 malfunction
did you fix this ?
dreadedwaygone is offline   Reply With Quote
Old 07-06-2011, 09:57 AM   #7
iluvdrt
Member#: 46248
82 Brat
Tan
It was related to my 5 spd conversion and a non existant NSS. I fixed it.
HELP URGENT!..stuck in Open Loop` jimtweet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-22-2007 01:51 PM
Why is my car staying in "accessory" even when I take the key out? chrisdeaner Electrical & Lighting 1 10-25-2006 10:08 PM
LTFT goes to 0 in Open Loop? <56K go away> Blennophobic Engine Management & Tuning 7 03-08-2006 10:25 PM
Utec Question : Why are the std map in open loop ? samh22a Engine Management & Tuning 1 07-01-2003 02:15 AM
Anyone help me with stuttering problem? Happens in high rpm's in open loop only... STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-31-2002 01:25 AM
