Old 06-08-2010, 04:28 PM   #1
mikeemoscooby
Member#: 247847
GC prez
white
Default ej18 / FRANKESTIEN!?
i have a ej18 and needing to know some info. Im wanting to put the 99.5 mm pistons from an sti in the block, are the cylinder walls thick enough. and if i use the sti rods it should make the stroke shorter i asume, how far would the pistons be from the deck, so it would lower my compression, but not sure waht the compression would be. also wanting to use the NA 2.5 heads if possible, what do you all think. would the compression be way to low, im looking for atleast 8.5:1 for a turbo. also is it even possible to use the rods or connect the 1.8 rods to the 99.5 mm pistons. thanks
mikeemoscooby is offline   Reply With Quote
RE:USDM EJ18 swap to EJ22 JDM or JDM EJ18 cbrkp Subaru Conversions 2 12-06-2006 04:07 PM
In which direction is the throttle body on EJ18? tonytiger Normally Aspirated Powertrain 1 03-23-2002 03:57 PM
Will any EJ18 ancillaries fit on a EJ22T? AndrewT Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-19-2002 07:56 PM
ej25 into ej18 L wagon, need help STiShawn Normally Aspirated Powertrain 0 09-10-2001 11:43 AM
Why Swapping an EJ25 with an EJ18 is bad...Comments? SubieKidTK Normally Aspirated Powertrain 20 06-13-2001 07:53 AM
