Old 06-11-2002, 10:19 PM   #1
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Default Knock Sensor Part Number
I asked this in FFI, but noone seemed to know, so hopefully one of you guys can help me out. I'm looking for the manufacturer's part number of either the stock sensor or the more sensitive knock sensor that seems to be used commonly with the Knocklink. I'm trying to find a datasheet for the sensor, so if anyone can provide me with a part number (manufacturer's, not Subaru) for the sensor, or a datasheet, I'd appreciate it.
Thanks
Mike
Narcisse91 is offline   Reply With Quote
Old 06-12-2002, 08:43 AM   #2
John at J&S
Member#: 2036
2000 Intrepid
Not sure, but I think the Link uses a Bosch sensor. There are several different Bosch numbers, but the most common one is 0261231006. They list for around $90. It has a molded fuel injection style connector.
It's a low output, untuned, two wire sensor. For best results, it should be used with a twisted, shielded pair cable. One of the wires is typically grounded at the ECU, the other is the signal. Saab, BMW, and Porsche use it. We use it in our RX7 application.
The Subaru uses a similar sensor, but one of the pins is internally grounded to the case of the sensor. This simplifies the installation to one wire, although it is still shielded.
Don't have the part number, but it looks the same as a sensor from a Maxima that a customer sent in for inspection. Here's a link to a search result for "knock sensor part number" at maxima.org:
http://forums.maxima.org/showthread....or+part+number
John at J&S is offline   Reply With Quote
Old 06-12-2002, 09:11 AM   #3
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Thanks. Now I just need to dig up a datasheet for it.
Old 06-12-2002, 10:31 AM   #4
John at J&S
Member#: 2036
2000 Intrepid
It's a piezo ceramic microphone with flat response to 15kHz, output is 20mv/g into 1 Mohm.
Knock Sensor Parts Number Spore Private 'Wanted' Classifieds 1 03-12-2009 06:45 PM
knock sensor part number!!!??? ges311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-30-2003 04:04 PM
2001 Knock Sensor Part # Ant Legacy Forum 2 09-23-2003 10:55 AM
Knock Sensor Part Number Narcisse91 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-11-2002 10:13 PM
MY00 knock sensor part #.........need some help here.. Aaron'z 2.5RS Normally Aspirated Powertrain 6 01-04-2001 03:36 PM
