Old 06-08-2010, 11:00 PM   #1
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Default 2.5 TB tensioner: superseded part numbers
Hello everyone. My 02 OBS is up for a timing belt service. In the midst of searching and pricing I've come across a new-in-the-box Subaru tensioner for sale p/n 13033aa040. subarupartswarehouse.com shows that it has been superseded with 13033aa042, which is what comes up for my car.
Does anyone know if there were any changes made to the tensioner when the p/n changed?
Thanks
kometo is offline   Reply With Quote
Old 06-09-2010, 12:57 PM   #2
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
OK well I'm going to try and answer my own question. I called a local Subaru dealer parts counter and asked. They replied that sometimes the part is upgraded or the manufacturer of the part changes, but didn't give me a specific reason for this particular part. If anyone out there happens to know, please do tell.
Thanks
Old 06-09-2010, 01:23 PM   #3
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
One more time. Found this TSB on Scoobymods. OK I think I'm done now.
Old 06-09-2010, 02:48 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Was there supposed to be a link to a TSB? You've piqued my curiosity!
Old 06-09-2010, 03:34 PM   #5
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Old 06-09-2010, 05:04 PM   #6
grafton
Member#: 187936
07 WRB STi
what is wrong with the older style tensioner like on the 2.2's?
grafton is offline   Reply With Quote
Old 06-10-2010, 01:42 AM   #7
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
I don't know if this info also applies to the 2.2.
Old 12-07-2010, 12:05 PM   #8
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Well it's been a few months since I replaced the timing belt, tensioner and rollers, as well as the tensioner bracket and bolts on my '02 OBS. I ended up getting all of the parts from Subaru, figured this was one job that I didn't want to short on. Temps have been in the teens the past few mornings and during coldstarts there is no more noise. Last winter there was a loud knock for the first few seconds during coldstarts. I don't remember seeing any obvious marks on the inside of the TB cover from where the belt might have slapped but I didn't spend too much time looking either and just cleaned it. I also checked the valves around the same time because I didn't know if they had ever been adjusted and found that they were all very close to spec (did a very slight adjustment and have not noticed any difference). So in my case replacing the tensioner, bracket and bolts seems to have taken care of the noise. But as always, YMMV.
My 2.1 Stroker build with part numbers so you can do it too! DSM Nexus Built Motor Discussion 79 10-06-2011 12:19 AM
2.5l hybrid question? oem part numbers needed! kinada423 Built Motor Discussion 14 09-11-2006 12:08 AM
STi RA 5 speed speedometer gear part number MK19_ Transmission (AT/MT) & Driveline 11 03-28-2005 12:01 PM
Ive done it... 2.5 swap, Guess my WHP numbers! woodruf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-18-2004 04:04 PM
RX7 Series 5 Turbo II Injectors, Part Number Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 11-21-2001 10:25 PM
