North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Private Classifieds
Old 06-09-2010, 02:36 PM   #1
2.5_IMP
Member Sales Rating: (19)
Member#: 163604
Legacy 1991 Legacy SS project car in Portland, OR
SOLD.
Please read the entire ad before contacting me.
If you still have questions once you are done, PM me.
If you prefer to talk on the phone, PM me your phone number.
1991 Subaru Legacy SS (Sport Sedan) with 164,281 miles. Clean Oregon title in my name.
This is a running, driving project car. I'm not parting it out.
If you are looking for something you can use immediately as a daily driver, this is not the car for you.
I'm not interested in trades. Cash only, no payments. Price is negotiable.
NO RUST! Car was born in Japan, lived in Maryland, Virginia, Florida, Colorado, and finally Oregon.
The Good.
EJ22T. UNMODIFIED. Closed deck, oil cooler, oil squirters for the pistons.
Rear differential 3.90 R160 VLSD (Viscous Limited Slip Differential)
Extensive service records, right back to the original owner. I even have the original window sticker.
Almost a full tank of Chevron 91 octane.
Oregon Crater Lake plate good until September 2010. I have the emission test results from the last renewal, and it passed with flying colors. No reason it won't again.
Highlights of the service records.
I can't list everything, but I have a binder full of receipts going back to 1991.
4EAT automatic transmission professionally rebuilt on 01/14/2003 at 105,797. $1684
Drive belts, spark plugs and d/s door lock replaced, sunroof adjusted at Lithia Subaru on 04/15/2004 $324.70
Valve cover gaskets, right front axle rebooted, brake system flush, power steering flush, and fuel system service at Lithia Subaru on 11/03/2006 $782.35
30,000 mile service, front and rear brake pads replaced, brake rotors resurfaced, and cooling system flush at Lithia Subaru 12/08/2004 $768.25
New water pump, thermostat, timing belt, and front seal installed by Isa's Auto Service on 11/15/2005 $433.00
Timing belt, thermostat, and coolant hoses replaced by Mountain Tech on 01/10/2007 $484.55
Used radiator installed by Mountain Tech on 1/19/2007 $175.00
Reman. alternator installed by Mountain Tech on 03/20/2007 $182.00
New alternator from United Battery 03/13/2008 $123.95 with lifetime warranty
Reman. OEM Subaru front CV axle replaced by Les Schwab on 10/11/2008 $177.09
Front brake pads replaced by Gresham Auto Repair on 08/14/2008 $95.00
The following are the parts I have replaced from 164,252 - 164,281 (04/07/2010 - 06/08/2010)
New NGK spark plugs and spark plug wires $51.00
All new OEM Subaru Genuine Parts: air filter, oil filter, fuel filter, pcv valve, various pcv hoses and fittings $142.25
Oil change using Valvoline 10W30. Fumoto oil drain valve installed $20.65
Used parts from various Pull-A-Part wrecking yards: carpet, front grille, sunvisors, gas cap, oil cap, exterior and interior trim. $???.??
All fuel lines replaced with Gates multi-fuel injection hose from NAPA $16.60
Cracked rubber inlet elbow on turbo replaced with un-cracked used one with 110,000 miles $15.00
Interstate Mega-Tron II reconditioned battery from Battery Specialists on Powell Blvd. $32.00 with one year warranty
MAF cleaned with proper MAF cleaner.
The Bad.
Car has been in two accidents - 01/2001 and 08/2001. The car was not totaled, title is still clean. All damage was professionally repaired, and I have all the receipts and records.
Clear coat from re-spray is peeling in some spots, and there is orange peel in others. The paint looks like it is 20 years old. Oh wait, it is.
Exhaust heat shields rattle. This is annoying, but doesn't affect anything.
Trunk release handle came off. Trunk release still works if you pull on the metal lever.
What needs to be fixed.
Needs a sunroof, a sunroof plug to be fabricated and installed, or a patch panel welded into the sunroof hole. The sunroof leaked like crazy when I bought it, and I got rid of it since my plan was to have the hole filled in. The interior is now completely dry. There are still some mold stains on the front seats. The sunroof is currently covered, and the car is stored in my car port.
Car pulls to the right. I took it in to The Line Up Shop to be aligned, and it could not be aligned due to the following problems: right lower control arm is bent, inner tie rods are worn and need to be replaced, boot on left side tie rod needs to be replaced. Their quote was just over $500, but all of these parts can be sourced from a wrecking yard and installed in your garage for a lot less money. When I bought the car, the previous owner didn't disclose that someone had obviously hit a curb and damaged the control arm.
Paint on the wheels is peeling, curbing, scratches, etc. The tires are Federal Formoza FD1s with a good amount of tread left.
Rear brakes should be done soon. One side is dragging. Car still brakes fine, but this was next on my list of maintenance.
Fog lights need some new bulbs.
What's missing.
Interior trim around back windows.
Headliner.
Power antenna.
Price drop - $900 or best offer. Lowballers will be ignored.
2.5_IMP is offline   Reply With Quote
Old 06-09-2010, 09:59 PM   #2
Florin1
Member Sales Rating: (15)
Member#: 163625
91 Legacy SS
Try bbs.legacycentral.org Thats where you will sell it ;-) Good luck. I got two of them.
Florin1 is offline   Reply With Quote
Old 06-09-2010, 10:03 PM   #3
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
You're probably going to have to be negotiable on price but that doesn't look too bad to me...
Bump for an honest seller.
AWD>FWD is offline   Reply With Quote
Old 06-09-2010, 10:58 PM   #4
2.5_IMP
Member#: 163604
Just posted it there today...
I'm flexible on the price. It's not that bad, I just wish I had known all of the problems it has when I bought it. I am ready and willing to answer any and all questions about the car, nothing to hide. I'm going to lose money on this no matter what, but at least my conscience will be clear. Thanks for the bump.
Old 06-10-2010, 05:11 AM   #5
azn0boi04
Member Sales Rating: (48)
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well if u decide to part it, i call that rear diff..
azn0boi04 is offline   Reply With Quote
Old 06-10-2010, 02:49 PM   #6
2.5_IMP
Member#: 163604
I can't part it out. I rent my place , and I'm not allowed to have any cars on the property that aren't running and driving. But if someone else wants to buy it and part it out...
Old 06-11-2010, 03:39 PM   #7
2.5_IMP
Member#: 163604
Friday bump. Willing to trade for cash.
Few more issues I forgot to mention: The exhaust heat shields rattle. Annoying, but it doesn't affect anything. Plastic handle for the trunk release popped off, but handle is intact, and trunk release still works.
I've seen EJ22T swaps listed for $900 - $1000...
http://www.ultimatesubaru.org/forum/...00&postcount=1
http://bbs.legacycentral.org/viewtopic.php?f=15&t=44128
...you get a whole car to part out. Sell the VLSD to a Datsun guy, sell the rebuilt 4EAT to someone, sell the front clip and trunk with spoiler, and you are well on your way to an affordable EJ22T swap.
Old 06-13-2010, 01:40 PM   #8
2.5_IMP
Member#: 163604
Bump. Second sunny day in a row in Portland, great for test driving a car with a big hole in the roof.
Oh wait, here's a complete sunroof assembly to fill that hole.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=44066
Old 06-14-2010, 01:52 PM   #9
2.5_IMP
Member#: 163604
Old 06-15-2010, 05:27 PM   #10
2.5_IMP
Member#: 163604
Bump. Make me an offer...
Old 06-16-2010, 01:58 PM   #11
2.5_IMP
Member#: 163604
Wednesday price drop - $1000 or best offer.
Old 06-17-2010, 08:58 AM   #12
2.5_IMP
Member#: 163604
Bump.
Old 06-17-2010, 12:49 PM   #13
Adema2626
Member Sales Rating: (28)
Member#: 110807
1979 Brat/94,01 Imp
Multi
I can't believe no one is jumping on this! Free bump.
Adema2626 is offline   Reply With Quote
Old 06-17-2010, 01:27 PM   #14
2.5_IMP
Member#: 163604
$1500 for an EJ22T and a 4EAT? Buy my car for $500 less.
http://portland.craigslist.org/mlt/pts/1787416272.html
Old 06-18-2010, 02:00 PM   #15
2.5_IMP
Member#: 163604
Payday bump. I'd like to sell the car this weekend so I can take it off my insurance.
If you don't have cash, I'll take a credit card through PayPal.
Old 06-19-2010, 04:06 AM   #16
2.5_IMP
Member#: 163604
Midnight price drop - $900.
Old 06-20-2010, 02:29 PM   #17
2.5_IMP
Member#: 163604
Sunday bump.
Old 06-20-2010, 11:54 PM   #18
575rider
Member Sales Rating: (14)
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
If I only had a bigger garage. It's worth buying just to pull the motor and drop it into my WRX, the 2.2T is one of Subaru's best.
free bump
575rider is offline   Reply With Quote
Old 06-21-2010, 02:23 AM   #19
2.5_IMP
Member#: 163604
free bump
Thanks. Just sold it. It went to a good home.
Old 06-21-2010, 03:23 AM   #20
Adema2626
Member#: 110807
1979 Brat/94,01 Imp
Multi
Congrats. Hope you got your asking price you should of. That was a steal.
FS/FT : Legacy SS yard sale In Portland - everything must go! 2.5_IMP NWIC Private Classifieds 0 06-05-2010 02:46 AM
1991 Legacy Turbo Spot Sedan, gray in Portland, OR boostedballs Complete Car Part-Out 3 11-23-2009 07:08 AM
FS in NY: 1991 Legacy SS, Auto, 89k, Some Mods Soarer Private Vehicle 'For Sale' Classifieds 6 04-02-2008 05:35 PM
1991 Legacy SS with JDM EJ20G snowjob Private Vehicle 'For Sale' Classifieds 7 11-23-2005 12:22 PM
FS 1991 Legacy SS Automatic Mk750 Private 'For Sale' Classifieds 0 06-04-2004 03:43 PM
