#1 |
Member#: 13535
SCIC
Vehicle:2006 300C SRT8 11 Durango 03 Vette Vert |
How much powerloss would there be from a leaking IC hose, and how much of a leak would throw a CEL?
#2 |
Member#: 11549
Vehicle:2002 WRX Sedan World Rally Blue |
One of the many time I pulled my IC, I forgot to tighten the IC to throttle body hose clamp, causing a boost leak. It caused a significant loss of power (not to mention a lot of noise). No CEL though
Scoobygator |
#3 |
Member#: 14334
Vehicle:2002 WRX Black |
I had the same problem with my ic hoses. I but the samco hoses on much better the ic hoses that are on the wrx are crap, subaru could have but better hoses on then, the stock ones. Try tighting the hoses clamp. Hope everything work out for you.
#4 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
your answer is: It depends on the size of the leak.
A big enough leak would cause no boost to be generated and your car will not have proper fueling. Cause for a severe loss in power. A small leak is less of an issue but will still cause fueling issues and potentially lower boost levels. |
#5 |
Member#: 14614
SCIC
Vehicle:2002 WRX Platinum Silver |
i blew a hole the size of a dime in my IC hose, and it turned out to be about a 227hp power loss. when i tried to drive away it stalled out.
#6 |
Member#: 13535
SCIC
Thanks for the info guys, I will be double checking my connections just to be sure.
#7 |
Member#: 4402
NESIC
Vehicle:2009 Outback XT DGM |
FYI
I replaced the Subaru hoses with a set of Samco and I noticed and that my boost is higher now. I guess it flows better ![]() Cheers Nick |
| Thread Tools | |
| Display Modes | |
| Power loss of using WRX IC pipe vs. STi IC pipe? | gopsu | Factory 2.0L Turbo Powertrain | 15 | 04-27-2006 06:54 PM |
| Expected power loss from ... | txl146 | Factory 2.0L Turbo Powertrain | 6 | 03-03-2005 11:30 PM |
| Power losses from additional alternator load? | Red Rocket | Factory 2.5L Turbo Powertrain | 6 | 08-17-2004 05:56 PM |
| Power loss from A/C | CyberVlad | Factory 2.0L Turbo Powertrain | 2 | 11-23-2003 04:19 AM |
| power loss from high heat? | 503 | Factory 2.0L Turbo Powertrain | 3 | 06-08-2003 12:56 AM |
