Old 06-11-2010, 02:11 AM   #1
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Default intermittent Check Engine light & fuel pump noise
Hello everyone. I have some questions regarding my '02 OBS. It has 105K and is bone stock.
It was running kind of poorly while the weather was hot and humid a few days ago. Bogging at low rpm and occasionally idling low/rough. The Check Engine light went on and off intermittently for a few days. Never cut out or had trouble starting though.
The fuel pump was making an intermittent buzzing noise during this time. I removed the access panel to check and it definitely was the pump. One thing I noticed is that if I rolled up the windows the pump would not buzz. If the windows were already rolled up all the way and I would lift the window switches, the electrical system would bog down and the pump would run quietly until I let go of the switches.
Since the weather cooled off the Check Engine light has not turned on and the fuel pump has stopped making noise.
It is supposed to be 90* this weekend so I will see what happens. In the mean time I was wondering if you guys had any ideas or advice for me.
Thanks
kometo is offline   Reply With Quote
Old 06-11-2010, 01:28 PM   #2
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Advice: Get the code read, then come back. Reporting a CEL without a code is like visiting the doctor and saying you just don't feel right.
LetItSnow is offline   Reply With Quote
Old 06-11-2010, 03:18 PM   #3
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Thanks for the advice.
Scan shows codes P0303 and P0304. Misfire in cylinders 3 and 4.
Old 06-12-2010, 03:12 PM   #4
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Well, the weather is not as hot as the forecast said and the car is running good. Which is totally cool. It's been a while since I've had a modern car and I'd forgotten how sweet on-board diagnostics can be. I know that the codes aren't always the answer to the problem but it sure is convenient when it works. I'm going to be replacing the timing belt and giving it a general tune up soon. So I'll be checking and cleaning whatever is possible. Guess I'll check back then if anything comes up. If anyone has any more info or advice for me in the mean time I'd sure appreciate it.
Thanks
NEED HELP! check engine lights all fuel related pmatty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-01-2010 05:42 PM
Intermittent Check engine light zez Normally Aspirated Powertrain 1 02-19-2009 05:40 PM
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 02:54 AM
Check Engine light on and Weird Noise! AphexDouble Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-10-2007 04:14 PM
1994 Subaru Legacy Check Engine Light and Fuel Odor Inside Car Modog100 Service & Maintenance 5 04-01-2006 11:32 AM
