Old 06-11-2010, 07:42 AM   #1
jzk25
Member#: 179120
Default H6 Lowmount GT3788 GC8.
Have been doing this job in the last week.
Lower rad support removed. Turbo and collector fitted and levelled.
LH manifold goes low to allow for lower rad hose outlet.
RH manifold goes high to allow for dump pipe to pass under.
X over pipes and 3.75" dump.
Overall position.
Forward mounted Jeep radiator.
jzk25 is offline   Reply With Quote
Old 06-11-2010, 07:44 AM   #2
jzk25
Member#: 179120
continued..
Cut down 600x240x100 intercooler with custom end tank.
Modified compressor housing.
Unfinished 3.75" exhaust.
Old 06-11-2010, 08:57 AM   #3
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
That is sick. My concern would be heat from the turbo heating up the coolant in the rad. Any kind of heatshielding going on that turbo? i.e. blanket, coating, aluminum/ti heat shield? Any other cooling concerns with that IC, would you mind letting us know what core that is? With such a low mount turbo what kind of underbody paneling are you planning on running? Worse placement for an intake filter than a CAI
Definitely looking forward to seeing this beast! Good luck!
OrbitalEllipses is offline   Reply With Quote
Old 06-11-2010, 09:10 AM   #4
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
So awesome. Great solution for cutting down the length of the turbo/intercooler plumbing. Between that and the displacement, that GT37 should spool really quickly for its size!
stoke is offline   Reply With Quote
Old 06-11-2010, 09:28 AM   #5
Notnice
Member#: 116554
06 founding member
of Tom Banks Hanks
Looks great, but will u have to drop the header every time u want to change the oil filter?
Notnice is offline   Reply With Quote
Old 06-11-2010, 10:13 AM   #6
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Might not have to drop the turbo manifold depending on how small his hands are and how much grip he's got... but definitely going to get oil all over it every time he changes it.
Old 06-11-2010, 03:37 PM   #7
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
BEAST...haha love it man, and i love that its in a GC, i may own a bugeye, but i think the GCs are my favorite body, especially since i first saw the video of gobstopper. guessin you built the engine up as well, specs on the engine?
also as others have mentioned..turbo heat and radiator= not cool....literally hahaha, yes bad pun not really intended. but im sure with as nice of a built as this is you will properly address the situation.
GL on build
dirtbikeridr12 is offline   Reply With Quote
Old 06-11-2010, 04:24 PM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
this is the best build thread on nasioc.
my eg33 GC is jealous!
eg33GC is offline   Reply With Quote
Old 06-11-2010, 05:08 PM   #9
jzk25
Member#: 179120
The engine is getting forged pistons and rods, the oil filter is just there for clearance purposes, there will only be an oil cooler adaptor and hoses and the filter will be remote.
Heat control will be sorted in due course, it is still a work in progress.
Old 06-11-2010, 08:57 PM   #10
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Does looking interesting, but I agree about the heat soaking issues of the IC and radiator and such. Wouldn't a side mounting option on turbo placement been more effective? What compression you going with on internals. Along with where are you sourcing them?
Last two questions. What are you gonna run for EM and will this be a track only car?
Seraphinwolf is offline   Reply With Quote
Old 06-11-2010, 09:19 PM   #11
jzk25
Member#: 179120
Been there and done that with side mounting a GT40 on an EZ30R. Very very difficult to fit in a RHD car. Lowmounting is stealth and keeps the manifolds short and the thickwall piping retains heat much better and keeps the heat out of the engine bay. The radiator copping radiant heat is not going to be an issue in my mind. The turbine housing and manifolding/dump are going to be ceramic coated and some simple heat shields will take care of the rest.
The car will be street registered and legal. Engine management is the usual Vipec V88.
I think the owner is going with CP's and Argo rods, same as the other EZ30R-T over here.
Old 06-11-2010, 10:59 PM   #12
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Over here being...? Cause I have to deal with emmission on my build.
Old 06-12-2010, 02:13 AM   #13
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
With the mention of RHD I would assume this is either a British or Aussie build. Likely the second.
Old 06-12-2010, 02:41 AM   #14
Seraphinwolf
Member#: 150922
97 OBS EZ30R
I concure. Aus seems to be where all the H6 builds are happening lately.
Old 06-12-2010, 11:20 AM   #15
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Pardon my ignorance of turbo setups, but don't you need a wastegate on that? Can't wait to hear this thing.
Old 06-12-2010, 01:47 PM   #16
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Very nice build. The short plumbing should help speed things up. Keep posting pictures.
Thanks
RSti_Spyder is offline   Reply With Quote
Old 06-12-2010, 02:28 PM   #17
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
agreed - this is sick build. Need more pictures.
Old 06-12-2010, 06:26 PM   #18
jzk25
Member#: 179120
Wastegates had not yet arrived, they'll be added next week. We are in Queensland Australia.
Old 06-13-2010, 04:18 PM   #19
chamerops
Member#: 215795
2006 wrx
Wouldn't the filter being so exposed pick up everything and get torn up pretty quick through dirt and what not. Also couldn't drive anytime theres water on the road. The turbo seems like it needs to be boxed off to help keep the engine cool and to keep the filter away from the elements. Other than that amazing build, I could only dream top do somehting like that
chamerops is offline   Reply With Quote
Old 06-14-2010, 01:51 AM   #20
kingbobdole
Member#: 85055
1989 XT-6
awesome!
kingbobdole is offline   Reply With Quote
Old 06-14-2010, 10:32 AM   #21
Bob the fabricator
Member#: 104246
What are you going to be using as a scavenge pump for the turbo oil drain? Just curious, as most options out there seem to be very expensive.
Nice build so far...
Bob the fabricator is offline   Reply With Quote
Old 06-14-2010, 12:50 PM   #22
GEE-OTTO
Member#: 201277
2009 Legacy GT
Things like this only happen outside the US NICE SICK clean ;
GEE-OTTO is offline   Reply With Quote
Old 06-15-2010, 04:40 AM   #23
jzk25
Member#: 179120
VDO do a reasonably cheap scavenge pump. I believe it is OE for Porsche 930 or something.
Completed exhaust.
Wastegates.
Random shot.
Old 06-15-2010, 09:11 AM   #24
GEE-OTTO
Member#: 201277
2009 Legacy GT
That thing will make insane power cant wait to see the videos and sound clips
Old 06-15-2010, 09:44 AM   #25
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Sometimes I think my car is modded, then I realize its really not at all.
Sweet project!
rexworx is offline   Reply With Quote
Jack L.'s 3.5 H6 - GC8 Race Car adam07specb Member's Car Gallery 43 01-14-2009 11:54 AM
GC8 Peanut headlights/Twin Turbo/H6? Soon2Bgreat Member's Car Gallery 17 02-13-2006 07:11 PM
Can an '01 H6 be bumped up to '05 H6 power? Siper2 Normally Aspirated Powertrain 7 07-29-2005 09:44 PM
WRX front brakes on GC8 and H6 Rears soobyfan Brakes, Steering & Suspension 4 06-07-2004 10:33 PM
Legacy H6 Upgrade for GC8 FatCatTurbo Brakes, Steering & Suspension 7 04-12-2002 08:26 PM
