Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-11-2010, 01:15 PM   #1
genny_1
Member#: 220074
09 WRX265 Wagon
Default 09 turn signal issue?
Hi all, probably nothing but thought I would put it out there. My driver's side turn signal flashes super quick (like they do when you have a bulb burnt out), but all of the bulbs are fine........any ideas?
genny_1 is offline   Reply With Quote
Old 06-11-2010, 01:32 PM   #2
ILSMKU2
Member#: 77908
2011 E92 ///M3
RIP 11, 09, 06, 03 STI's
might want to recheck the bulbs. hyper blinker is usually from a dead bulb.
ILSMKU2 is offline   Reply With Quote
Old 06-11-2010, 02:25 PM   #3
Darkmatter1986
Member#: 233518
2009 WRX CSK Tuned
..RIP... 2013 WRX...
i had this exact same problem, pull out the bulb and put it back in securly, (disconnect battery in process) should work no problem, at least thats what i did.
Darkmatter1986 is offline   Reply With Quote
Old 06-11-2010, 02:34 PM   #4
J.biz
Member#: 191825
2009 WRX Hatch
same problem here too.. it was the ground wire on the socket for me.. i just messed with the wire and no more problems!
J.biz is offline   Reply With Quote
Old 06-11-2010, 02:53 PM   #5
genny_1
Member#: 220074
09 WRX265 Wagon
Thanks guys, I will try it later today.
Old 06-11-2010, 04:50 PM   #6
themicrohawk
Member#: 224754
2009 WRX 4DR Prem
Dark Gray Metallic
Start with this suggestion.
themicrohawk is offline   Reply With Quote
Old 10-25-2012, 12:20 PM   #7
bluewrx42
Member#: 336104
2015 STi
Default Left blinker, then right, and now left again and again
Changed the left blinker after one month of ownership Feb 11, and just 1,888mi's, then the right at 10,453mi in Sep 11, and the left went back out beginning of month Oct 12 with 26,621mi, and the left is doing it again with about 1,400mi more on it.
What does the dealer do to fix it cause I don't like dealerships?
bluewrx42 is offline   Reply With Quote
Old 10-25-2012, 02:02 PM   #8
bluewrx42
Member#: 336104
2015 STi
I know your post was a while ago, but I would like to make sure owners take a close look at the bulb when this happens, The blinker/parking light has two elements in it. So it might appear that it isn't burnt out cause you see the parking light element still working, but the blinker element IS burned out.
95 Impreza Turn Signal Issues MrFisher Electrical & Lighting 1 04-10-2010 11:38 PM
Moonroof/Sunroof/turn signal issue. HELP 18rabbit Electrical & Lighting 3 08-18-2009 03:51 PM
Quirky turn signal issue gkauno Car Audio, Video & Security 4 02-11-2009 12:47 AM
turn signal issues bjsid Legacy Forum 2 07-13-2003 04:39 PM
Turn Signal Issues borchert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-16-2002 12:24 AM
