Old 06-12-2002, 11:25 AM   #1
secured-nor1
Member#: 11164
Question anyway to run winamp plugins on LCD screens?
secured-nor1 is offline   Reply With Quote
Old 06-13-2002, 01:52 AM   #2
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
not so much as your thinking that i know of.... but if you get a vid card with an rca out you can just run all the vid to the lcd. then you can use winamp
check out www.northursalia.com
he has a howto in his mods section on how to put an lcd screen in the visor.
-Dustin
DustinR is offline   Reply With Quote
Old 06-13-2002, 11:02 PM   #3
nuetz
Member#: 9188
2002 impreza wrx
silver metalic
yes there is. do a goggle search for: mike lynch winamp lcd
you should get a site called car mp3 project or something of that nature. download the winamp plugin, and configure the .INI file to your likeing, or email me and i will send you my ini file.
then you need to build the display. i got my display of eio.com for about 20 bucks, but the prices vary. what you want is any size lcd, mine is a 40x4, with an HD7..... series controller. then wire it up to your paralell port with a hacked printer cable.
there is tons of info, some you can get to from mike lynches site. if you want to just buy one, try matrixorbital.com
they are pricy though...
nuetz is offline   Reply With Quote
Old 06-14-2002, 11:18 AM   #5
parid
Member#: 16336
2002 WRX Wagon
If your thinking about putting a computer in your car I would recomend finding some way to clean up the power. Its really nasty. If you get one of them cigarette lighter ac-dc converters you will get really dirty power. It will mess with your sound card and just generaly be unplesant. I have seen a lot of people put a small UPS in the car to help fix this problem.
Good luck though! I would love to see pictures when you get it done.
parid is offline   Reply With Quote
Old 06-14-2002, 11:58 AM   #6
zmog
Member#: 11914
1998 Legacy L
There are some computer power supplys that run off of 12 volts. I haven't seen one for a while, but they're out there - somewhere. I honestly can't see any reason for them to exsist except for use in cars - and that seems like a nearly non exsistent market... Anyways, they exsist, and are rather pricey as I recall.
Michael
zmog is offline   Reply With Quote
Old 06-17-2002, 03:11 PM   #7
Nitro Soda
Member#: 19299
1997 Impreza Wagon
if you do go this route look for a "switching" power supply. these have power conditioners in them. i once hacked a laptop mother board and put it in the door panel (prolly not the best place for it but i was just trying it out). the laptop mom board is cool cause i kept it using the stock battery... so basically i was just keeping the batter topped off!
i used it to run a full blown version of winamp for tunes and a GPS hooked up for nav. was cool but a lil clugey
Nitro Soda is offline   Reply With Quote
Old 06-17-2002, 05:10 PM   #8
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
If you can somehow find a RioCar / empeg head unit for sale, they are, IMHO one of the best solutions for digital audio (MP3s, WMAs or WAVs) in your car. I'm pretty sure they stopped making them though, so good luck finding one used.
www.empeg.com
scotty305 is offline   Reply With Quote
Old 06-17-2002, 06:17 PM   #9
Blackskull
Member#: 5616
2002 Impreza WRX
Or build your own with one of these...
http://www.nexcom.com/product/ebc/
Most of the boards come w/LCD panel support already.
Blackskull is offline   Reply With Quote
Old 06-18-2002, 11:01 AM   #10
zmog
Member#: 11914
1998 Legacy L
I would advise using a laptop hard drive as well. You need an adapter since laptop harddrives only have one plug that have both the IDE interface and the power in it... But, if you do use a regular hard drive, make sure to dampen it somehow. All that shaking would kill a normal hard drive fairly quickly methinks. I know you cat get cages that fit in 5 1/2" drive bays that hold hard disks - they are designed to quite your hard drive but they should also do a good job of protecting it. If you are cheap you could just wrap it in a whole lot of really soft foam.
any way to get alternate VIDEO onto NAV screen (not dvd screen) mmontgom Tribeca Forum 13 09-28-2006 10:37 PM
is there any way to get rid of a diff screen name... psa411 Off-Topic 43 03-17-2005 07:28 AM
OK computer gurus. any way to get admin rights on my work laptop? (Win 2k pro) Eric SS Off-Topic 10 10-30-2004 02:15 AM
Any way to make Winamp 5 remember its window settings? TimStevens Off-Topic 9 03-26-2004 01:16 PM
Any way to tune a WRX on a 2-wheel dyno? oldmansan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-02-2002 11:45 PM
