Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-12-2010, 09:27 PM   #1
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
Default Problems after STi swap
I just swapped a 2006 EJ257 motor into my 02 WRX and am having what feels like a fuel cut when accelerating hard. I've done some research and it sounds like overboost.
I went with a 2004 ECU and wiring to ease wiring incompatibilities. It just occured to me that the ECU I have is expecting a VF39 turbo, while the 2006 motor has a VF43. Could this be causing my overboosting issues?
Even if not, seems like I'll be needing a custom tune. Can a dealer or tuner change my ECU to 06?
BMXspears is online now   Reply With Quote
Old 06-12-2010, 11:42 PM   #2
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
06 sti has the vf39,,, vf43 was 07
woodys77 is offline   Reply With Quote
Old 06-12-2010, 11:45 PM   #3
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
Not according to the "all knowing" Unabomber...
Old 06-13-2010, 09:23 PM   #4
woodys77
Member#: 192147
2007 STI EfiLogics
you must be referring to this...... http://forums.nasioc.com/forums/show...ht=vf39+06+sti
Well have to have a talk with him on that
try this.....
http://forums.nasioc.com/forums/show...ight=turbo+faq
boost creep is common maybe a couple turns out on your wastegate arm might help.
Old 06-13-2010, 11:30 PM   #5
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
try this.....
I see. Well that is a relief as I didn't want to deal with mismatched ecu's. I have a stock dp, catless midpipe (cheaper than repairing worn cat) and stock axle back. Could my catless midpipe be causing the problem?
If I did get a vf43 down the road, would that require a tune?
Problems after ej257 swap blkwagon Subaru Conversions 0 11-25-2008 01:06 PM
Problems after GC Swap Jubert69 Newbies & FAQs 6 10-27-2008 09:15 PM
Problem after engine swap....HELP. bjpeppers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2007 08:03 AM
Problem after turbo swap 04subyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2007 11:20 AM
Emissions problem after motor swap jdmgc8 Subaru Conversions 15 09-25-2004 02:56 PM
