Old 06-14-2010, 10:03 AM   #1
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
Default time to play name that exhaust noise
had a moment at a track day this weekend. I ended up in a big mud puddle... or should I say, the big mud puddle wanted a ride IN my car.
suffice to say, I have a noise now under the car from the exhaust. Happens in any gear from 4K+ rpm lifting off the gas completely, seems to be a rattle/hiss So I'm guessing this is an exhaust leak of some sort? Only happens when it's loaded by the engine, noise is not audible when reving freely.
Sir-Knight is offline   Reply With Quote
Old 06-16-2010, 09:52 AM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
what exhaust do u have? it may be a loose baffle or something.
PA-Outback2000 is offline   Reply With Quote
Old 06-18-2010, 12:05 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
If it rattles more with the gas off, it might not even be the exaust. You could have stuck a rock or something around the exhaust piping / heat shield area... Did you thoroughly wash the underbody of the car after your puddle bath? Maybe something just got loose...
Old 06-18-2010, 02:11 PM   #4
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
lol sounds weird but check your lugnuts, i had the same noise and it ended up that 4 of 5 were loose on my front drivers side wheel......just a suggestion
acemyles2.5i is offline   Reply With Quote
Old 06-18-2010, 05:13 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
My guess is also a stuck rock or a built up of dirt somewhere that's rattling. Get the undercarriage of the car washed and see if that changes anything.
Mike
GrimmSpeed is offline   Reply With Quote
Old 06-21-2010, 09:18 AM   #6
Ty55
Member#: 237195
2007 Impreza 2.5i
WY Scooby Lover
Mike
This is probably the case. In the winters if I drive through a lot of deep snow my exhaust will sound terrible becasue the snow gets packed around the pipes. But as soon as it melts off its fine. Probably just something stuck somewhere under there.
Ty55 is offline   Reply With Quote
Old 06-21-2010, 11:28 AM   #7
BE6STI
Member#: 192815
2003 Outback
Regatta Red Pearl
Check your carrier bearing on your driveshaft might have something rattling on that
BE6STI is offline   Reply With Quote
Old 06-23-2010, 07:48 PM   #8
Mikesubrs
Member#: 243627
2002 Impreza Wrx Wag
Midnight Black Pearl
if you wash ur undercarraige i suggest using lukewarm water (room temp)
Mikesubrs is offline   Reply With Quote
it time to play... whats that noise! mcrae2112 Normally Aspirated Powertrain 7 05-11-2007 12:04 PM
It's time to play... Name That OTter! Strider Off-Topic 57 04-01-2006 06:26 AM
Time to play name that mod BeratE Electrical & Lighting 7 11-06-2005 10:00 AM
It's time to play...Name that Movie! chyisan Off-Topic 21 11-04-2003 02:45 PM
Time to play.... Name That Bumper! Scooby South Interior & Exterior Modification 5 02-26-2001 11:06 AM
