Old 06-14-2010, 11:42 AM   #1
BDZ
Member#: 246673
Default Oil Leak
I am in the process of a timing belt replacement on my 2006 2.5i Impreza wagon. I found a small oil leak behind the timing cover. It appears to be "weeping" from the right piston service port plug on the driver's side above the water pump. The leak is small but enough to wet the lower center timing cover gasket to the point of swelling and failure.
Is this leak area common?
I am planning on getting a new plug seal and resealing the plug threads with threebond 1105 per the factory manual.
Any suggestions otherwise?
thanks,
Z
BDZ is offline   Reply With Quote
Old 07-09-2010, 10:44 AM   #2
RiverHouse
Member#: 208514
1998 impreza L wagon
shiny green!
Default same here
I have a oil leak coming from the timing belt cover as well. I haven't opened it up yet, but I suspect the same problem. Not to hijack the thread, but is there any else it could be besides the piston service port plug? What is a piston service port plug anyway? Any suggestions would be helpful!
RiverHouse is offline   Reply With Quote
Old 07-09-2010, 11:24 AM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's common for stuff under the timing cover to leak. Mine is too, usually it's the cam or crank seal. Just like everything else, seals on rotating parts wear. The piston service port is used for wrist pin insertion. I've not heard of many instances of leakage, but anything's possible.
KillerBMotorsport is offline   Reply With Quote
Old 07-13-2010, 09:24 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^^ Funny I said that. Mine was leaking from the same spot, the wrist pin access ports!
Old 07-15-2010, 07:11 AM   #5
flightwatch
Member#: 231058
2015 F-150
What are you talking about?
flightwatch is offline   Reply With Quote
occasional oil leaks any one? bman10167 Newbies & FAQs 3 06-14-2010 11:12 AM
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 08:23 PM
weird oil leak/AC leak? NateDogg Service & Maintenance 2 05-03-2004 05:23 PM
New Omori Oil temp install and oil leak mhbrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-22-2003 08:10 PM
oil leak from front of engine, oil pump? drftsub Legacy Forum 14 01-06-2003 08:44 PM
