Old 06-14-2010, 11:28 AM   #1
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Default Car Dies When Clutch Pushed In..?
Hey Guys . as the title states ... My car dies when i clutch in...
Driving home from work a few days ago.. coming up to a redlight. I clutch into downshift. and the engine revs just drop to zero .. didnt even sputter. everything just turned off.. anyways . got the car restarted and made it home ..
now sitting with the engine running at home ... as soon as you put the clutch in to put it in gear. the revs drop to zero again .. and the car is dead ..
Well now the car will not even start. It will try to turn over.. but seems like it has quite a bit of resistance..
The Car is a 1999 RS with a 2005 Outback 2.5 Engine ..
anyone ever heard of anything like this ? thanks for any help guys !
saar is offline   Reply With Quote
Old 06-14-2010, 11:46 AM   #2
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
You check for a short on the clutch switch? im assuming you have one, but it sounds like hitting that switch is killing the car, also did you have to clutch in to engage the starter? sounds like thats where i'd start.
jakedademon is offline   Reply With Quote
Old 06-14-2010, 12:08 PM   #3
vrusso
Member#: 207074
2015 STI
You know you're jealous
Sounds like your TPS is in need of replacement.
Edit: Actaully reading your post a bit more clearly you say you can have the car in neutral and it runs fine and only stalls when you put in the clutch?
vrusso is offline   Reply With Quote
Old 06-14-2010, 12:20 PM   #4
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
That is Correct.. As of right now the car is not able to turn over at all ... when i initially encountered this problem, i was able to start the car .. it would run/idle no problem ... and upon pressing the clutch in. it would drop the revs to nothing ...
the Clutch switch seems like a likely culprit. I don't know though ?
I have never encountered a car Turning off while Clutching in?
Old 06-14-2010, 07:24 PM   #5
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
well.. I Tried starting the car with a boost again here after work ... and the car will not even turn over now ... just will not go.
I should have mentioned in my original post that the car runs off a Autronic Standalone. Would a Dead Sensor or faulty ECU Connection Perhaps be my problem>?
I suppose i will just send it into a shop for some diagnosing .. I just fingured i would see if anyone had any ideas as to what could be happening?
Old 06-14-2010, 07:34 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Are you sure it's not mechanical? Is there something in there physically preventing the engine from moving? I kinda doubt it based on your symptoms, but it's something to look at.
If that's all good, my first instinct is the clutch switch. Test it out and see if it's still working correctly. I wasn't aware that one the car is running that this switch would do anything. Is there any physical linkage messing with wiring?
Crap Idle Problem, Can't hold idle, sometimes dies when I push clutch in TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-02-2008 09:40 PM
Rattling noise when I push in the clutch?? The Chef Transmission (AT/MT) & Driveline 2 06-18-2008 09:22 PM
Car dies when trying to idle / dying car VideoGameWrx Commercial ECU Reflashes 8 01-14-2008 12:25 PM
Car dies when clutch depressed Phatzilla18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-15-2007 08:34 AM
Car dies when cold. Ben Buker Normally Aspirated Powertrain 1 02-08-2001 05:21 AM
