Old 06-14-2010, 10:16 PM   #1
WinterSubie
Member#: 243234
2009 Hatch
Default Cat pipe question?
Does anyone no which, if any, of these cat pipes will work on an +08 hatch.
http://www.boxer4racing.com/exhaust.htm
WinterSubie is offline   Reply With Quote
Old 06-15-2010, 09:31 AM   #2
GEE-OTTO
Member#: 201277
2009 Legacy GT
NONE will work unless you plan to install Borla UEL headers those mid pipes are for 2005 and older RS/TS
GEE-OTTO is offline   Reply With Quote
Old 06-15-2010, 07:08 PM   #3
WinterSubie
Member#: 243234
2009 Hatch
Yes it would be to borla headers but I can't find any info anywhere on what catpipes fit the +08.
Old 06-16-2010, 09:50 AM   #4
PA-Outback2000
Member#: 161832
2000 Outback Limited
unless u weld one in, none fit "stock". they will fit if u use the borla header.
PA-Outback2000 is offline   Reply With Quote
High Flow cat pipe questions ScubaruImpreza05 Normally Aspirated Powertrain 20 05-20-2009 10:41 PM
CA Stromung 3rd Cat Pipe..Secondary Pipe w/ cat! markswrx05 Engine/Power/Exhaust 18 01-10-2007 01:20 PM
CA Stromung 3rd Cat Pipe..Secondary Pipe w/ cat! markswrx05 Engine/Power/Exhaust 6 01-02-2007 01:06 PM
TXS stealthback cat pipe question Agkelos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-27-2005 11:40 AM
up pipe, down pipe, and cat back question 04subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-22-2003 08:53 PM
