Old 06-15-2010, 12:21 AM   #1
fraktal
Member#: 228006
2004 Forester XT
6MT/R180/5x114.3/DCCDPro
Default Custom AC line question
is it possible to take the low pressure/high side line from one car, cut it along the hardline and have it welded to another oem hardline's firewall/compressor fittings?
i don't see why not, but i don't know so that's why i'm asking lol.
basically i would rather switch to a 2008 sti LP line setup (which runs under the tmic) instead of bending the hell out of my original hardline and smash it into the firewall. i would cut the compressor/firewall fittings off my stock line and then fit/cut/weld as needed to use the 08's line and routing.
appreciate serious responses thanks.
fraktal is offline   Reply With Quote
Old 06-16-2010, 01:59 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
FROM WHAT I KNOW:
Technically yes, but the aluminum used in AC piping is literally recycled soda cans so most shops will say no. Check the Yellow Pages in your area for an automotive AC specialist. Yes, the yellow pages. You should find a shop or three that will make customs lines, so they can cut and use the $Texas AC line crimper they have an make it that way. I thought about doing this with my car due to a leak and opted for the $125 OEM line which I'm picking up tomorrow.
Old 06-16-2010, 11:41 PM   #3
fraktal
Member#: 228006
2004 Forester XT
thanks for the reply unabomber. i had a feeling it wouldn't be "that" easy.
another idea i had was to just cut the stock hardline near both block fittings and have some new ac fittings welded on to the ends of the cut hardline. then i could run an aeroquip hose or something in between, routed under the tmic?
Old 06-21-2010, 07:17 PM   #4
mcandrewsr
Member#: 148756
If you're going to use a hose.. I'd make sure it can handle the pressure of the discharge/liquid line (high pressure). If I'd be doing it, I'd see if I can wing up copper to it instead of the aluminum.
mcandrewsr is offline   Reply With Quote
Old 06-21-2010, 11:52 PM   #5
piddster
Member#: 144285
1993 UHEV Legacy
You should have an industrial fluid conveyance business in your area that can handle what you need. Industrial Areoquip dealers are a great resource for all things fluid related.
piddster is offline   Reply With Quote
FS: AC System AC Compressor/Belt/4 AC lines/Bracket the real suby dude Engine/Power/Exhaust 3 03-26-2009 04:51 PM
Replaced AC lines-how crucial is it that the AC Drier be replaced on WRXs ScoobyNubieToo! Service & Maintenance 4 05-27-2008 06:57 PM
WTB: 04 Sti Ac Lines or 04 and up Wrx ac lines.. NotoriousD Private 'Wanted' Classifieds 4 08-05-2006 09:56 AM
AC line question gummy Newbies & FAQs 7 07-12-2006 11:33 PM
AC line and larger intercoolers - STi lines? ndw1138 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-19-2003 07:48 PM
