Old 06-15-2010, 01:05 AM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default OBS major issues
ok, hereīs the deal. I changed my head gasket due to overheating. The same day I took it out of the shop I noticed the auto gearbox was working funny. (i know, not this forum, please keep on reading) It changed gears abruptly and coudnīt stay steady on a gear. Plus, when I accelerated the car from 0 with my wheels turned, it moved very slowly. Just as if I had the emergency brake up. Now with the engine. It was still overheating. I didnīt let it overheat, but I did notice the needle going up with some speed. It had a leak on the radiator, fixed. But still overheating!! I was driving normally, checked the needle, a little over half (not normal, but I was half a block from home) less than 5 secs later, the car stoppped. The temp needle was all the way to the top, and the fuel gauge in its lowest position plus fuel light on. It has fuel, just put some gas 5 mins before. the engine is not sos hot, but not overheated. Even with the car off, the needle was still up and my fuel pump was working! Took the battery terminal off but a soon as I put it back on, the needle went up and couldnīt start the car, even after 30 mins of cooling down. I now its a HUGE case, but what could possibly be wrong?? thanx
alejo is offline   Reply With Quote
Old 06-15-2010, 01:22 AM   #2
XanRules
Member#: 157348
It's rowdy outside
I ain't signin' s***
blown headgasket at best.
Blown motor at worst.
Also why did you post the same paragraph twice?
XanRules is offline   Reply With Quote
Old 06-15-2010, 11:33 AM   #3
alejo
Member#: 170081
2004 2.5RS
blue
sorry about the paragraph, my computer failed . I filled the radiator with water all the way to the top an tried to turn the car on, it didnīt throw the water upward like it does when you have a blown head gasket. Is that a viable "test"?
Old 06-15-2010, 02:04 PM   #4
XanRules
Member#: 157348
It's rowdy outside
nope.
Not at all.
Check the color of the coolant and the color of your oil.
Old 06-15-2010, 03:03 PM   #5
LEKO
Member#: 238293
2002 Impreza 2.5TS
Midnight Blue Pearl (MBP)
If your prestone overflow is clean you may see "oily/dark" deposit in it. It's a sign that the oil/coolant mixes together (head gaskets gone...).
Also, if you see air bubble in the overflow (pressure in the pistons pushes air in the cooling system), head gasket gone...
Is there more smoke coming out from your exhaust... coolant goes in the pistons...
A defective radiator cap can also makes your engine behaves like the head gasket is gone!
Hope it will helps you.
LEKO is offline   Reply With Quote
Old 06-15-2010, 03:21 PM   #6
xsv141
Member#: 231904
2007 WRX
UGM
i was having the same problem in my 07 obs and at first it was a defective radiator cap then it was doing it again so took it back to the dealer and it was in deed a blown head gasket!!!!
xsv141 is offline   Reply With Quote
Old 06-15-2010, 04:24 PM   #7
Tessai
Member#: 214184
1999 Legacy Outback
When you refilled it with coolant after changing the headgasket and later the radiator, did you get all the air out of the system?
You need to fill it with coolant, let the car get to normal operating temp (thermostat open) and shut the car off. Let it cool down, then take the radiator cap off again. The coolant level will be a little lower as your block now contains some of the coolant. Top it off again.
If you got air in the system it could overheat still.
No idea on the rest of your issues, sorry.
Tessai is offline   Reply With Quote
Old 06-15-2010, 07:52 PM   #8
vrusso
Member#: 207074
2001 Impreza Outback
Silver -180k and counting
I would second this. If all went well with your orginal HG replacement it sounds like you need to burp the system and get the air out of it. If there is air in the system the Thermastat wont open and allow the coolant to flow and cool the engine.
vrusso is offline   Reply With Quote
Old 06-15-2010, 10:12 PM   #9
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
A similar thing happened to me with my legacy. The engine would not be hot, but the temp gauge would jump and stall my car and it would not start for a day. I know for sure the engine was not hot because the valve covers were just warm. I'd go back the next day and it would run fine. It turned out to be a bad ground for me, after I fixed the ground I have never had the problem since. If it is a ground it could also be messing with your auto tranny, I did not have this problem because I have a 5 speed. Hope this helps, it was a big pain in the arse to find the ground, 3 weeks it took!
Jessekrs123 is offline   Reply With Quote
Old 06-16-2010, 10:30 AM   #10
alejo
Member#: 170081
2004 2.5RS
blue
Hi, thanx for all your input! It was a bad ground with a sensor. Canīt remember which one it was. problem solved. The next issue is clenaing the radiator and changing the cap. Thanx, again.
Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) bcustom561 Service & Maintenance 2 05-20-2010 08:17 PM
Obama's Science Advisor Spectacularly Wrong About Major Issue in Field of Expertise rally_wannabe Political Playground 188 09-10-2009 03:35 PM
Small/Major issue with wagon FSB...PICS jsalassi Brakes, Steering & Suspension 14 08-31-2007 10:20 AM
Major issue with detonation before and after ECUtek tune JeffrWRX Factory 2.0L Turbo Powertrain 11 03-04-2006 09:25 PM
XP help- Not a major issue Amazake Off-Topic 7 12-03-2005 05:13 PM
Message Board Statistics All times are GMT -4. The time now is 02:55 AM.
