Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 06-15-2010, 03:06 AM   #1
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
Default Reversed Suby 4WD problem
Like the title said i have a small problem, i'm trying to figure out a small dilema, i'm not even sure it can be but if it can i'm hopeing someone here may have the answer.
Problem, am trying to figure out if a reversed suby engine and trans mounted in a VW, ie rear engined, trans in front, will work in a 4WD configuration, the problem i see is the torque split and trying to figure out how to sort it out, vehicle will be used on tarmac if built so it has to steer around cnrs.
any help and advice appreciated
Cheers
wsc is offline   Reply With Quote
Old 06-15-2010, 04:19 AM   #2
flightwatch
Member#: 231058
2013 Genesis Coupe
You would have alot more luck down in the conversions forum
flightwatch is offline   Reply With Quote
Old 06-15-2010, 04:40 AM   #3
wsc
Member#: 182830
dark blue
sorry mate i wasnt sure where to post it have moved it as suggested
Thanks
Subie Common Problems? Avalanche Newbies & FAQs 22 01-25-2009 11:23 PM
Non subie car problems clemsonteg South East Region Forum 15 06-12-2007 10:56 PM
Wheel spins in reverse after stop. Problem? 96lx Brakes, Steering & Suspension 5 11-09-2006 10:20 PM
MT reverse and 1st problem Bootleg Transmission (AT/MT) & Driveline 5 12-14-2004 12:31 PM
HELP!!! Wierd 4WD Problem mhj Legacy Forum 5 02-02-2001 07:18 AM
