Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-15-2010, 05:39 AM   #1
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
Default reversed Suby drive train dilema
Moved on advice
Like the title said i have a small problem, i'm trying to figure out a small dilema, i'm not even sure it can be but if it can i'm hopeing someone here may have the answer.
Problem, am trying to figure out if a reversed suby engine and trans mounted in a VW, ie rear engined, trans in front, will work in a 4WD configuration, the problem i see is the torque split and trying to figure out how to sort it out, vehicle will be used on tarmac if built so it has to steer around cnrs.
any help and advice appreciated
Cheers
wsc is offline   Reply With Quote
Old 06-15-2010, 10:32 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm
all the reversed layout cars that i have seen use a different transmission
so unless you can cut your own gears it will be tough
Old 06-15-2010, 03:50 PM   #3
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
fairly epic project. reversing the rotation of the diffs is not an easy project. There isn't room inside the case to flip the diff around. So you'd have to do some serious machining on the transmission and differential cases to get it all to work.
Also, at least for the divorced diff, possibly for the one in the trans as well, the pinion is not centered. So the gears will not properly mesh when reversed, so you'll have to get some custom gears made.
unless you plan to get the engine to run the other way.....but that's a whole new can of worms.
if you can get over that, the torque split won't be an issue. As long as it's an older EJ transmission (pre-2002, IIRC. the newer ones have a 1.1:1 transfer gearset that theoretically gives them some rear bias), there isn't any bias to one end or the other.
Numbchux is offline   Reply With Quote
Old 06-15-2010, 04:23 PM   #4
AKGC8
Member#: 1305
2000 Impreza
Or don't mod anything and set the world speed record for a VW in reverse.
AKGC8 is offline   Reply With Quote
Old 06-15-2010, 04:45 PM   #5
johnny p
Member#: 141232
02 v7sti wagon
signal green
www.subarugears.com flipped ring and pinions
johnny p is offline   Reply With Quote
Old 06-15-2010, 05:59 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
interesting ...
use the kit above then find a matching diff for the front ..
Old 06-15-2010, 07:02 PM   #7
wsc
Member#: 182830
dark blue
fliping the diff etc isnt a problem as everthing is available and reasonbly priced, my main concern is the torque split, so it dosnt wind up a massive understeering car under power.
cheers
Old 06-15-2010, 09:50 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if its 50/50 as a front engine ... it should be 50/50 as a rear engine unless you have a dccd
Old 06-15-2010, 10:57 PM   #9
wsc
Member#: 182830
dark blue
yeh thats right but at 50-50 with applying power out of a cnr it will understeer badly wont it, i was of the opinion you had to have a rear bias under power or am i wrong, this is the bit that worries me
thanks for the input
cheers
Old 06-16-2010, 12:31 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nope it 50/50 unless it has a dccd
Old 06-16-2010, 12:38 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Saw one on a buggy at outfront motor sports.
Old 06-16-2010, 03:09 AM   #12
Numbchux
Member#: 71658
'84 Brat
cheers
it *should* understeer less than a subaru as the torque split is the same but the weight bias is in the rear. the rest is up to your suspension setup.
WTT 6-speed drive train for 5-speed wrx drive train takeshi999 SCIC Private Classifieds 24 05-11-2008 09:46 PM
subie tech training Ne14korn Mid West Subaru Owners Club Forum -- MWSOC 11 02-16-2005 04:44 PM
Westminster Broomfield Subie guys train to D&B FlooredSubaru Rocky Mountains Impreza Club Forum -- RMIC 0 02-23-2002 11:51 AM
MY99RS drive train FS Joe Hogan Texas Impreza Club Forum -- TXIC 1 03-21-2001 08:55 AM
New Wrecked Impreza and Drive train pisc Greg555 Mid West Subaru Owners Club Forum -- MWSOC 12 01-19-2001 01:39 AM
