Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-15-2010, 06:12 AM   #1
paul@YimiSport.com
Member#: 129072
2008 WRX STi
Laguna Seca Blue
Default Yimi Sport Tuning: 2002 WRX, HTA68, stock motor, 91 octane = 338whp/312wtq
Ambient Temp: 70*F
Elevation: 1200ft ASL
Car: 2002 Subaru WRX
Tuner: Paul Leung
Dyno Info: DynoJet
Peak HP at RPM: 338.39 whp @ 6400 rpm
Baseline HP for a stock car: 240-245 whp (STI)
Target Boost: 21.5 psi
Target AFR: 11.0:1
Fuel: CA 91 octane pump gas
Engine/Power Modifications:
FP HTA68
Invidia uppipe
Invidia catless downpipe
Custom Yimi Sport midpipe with a Magnaflow axleback
Greddy FMIC
DW 750 CC injectors
Walbro 255 FP
Yimi Sport custom CAI
Silicone turbo inlet
Grimmspeed EBCS
OpenSource tuned
This was the glory run (hey, this is Proven Power Bragging ) After hearing the customer talk about how he thrashes his car in the canyons I decided to dial it down a bit to give the stock block some extra safety margin. IIRC, he left grinning with 331whp. Not too shabby for a car that was a couple fries short of a Happy Meal when it first showed up at our door
paul@YimiSport.com is offline   Reply With Quote
Old 06-15-2010, 06:47 AM   #2
stidoc
Member#: 147579
Impressive numbers for a 2.0L on CA pump. Nice.
stidoc is offline   Reply With Quote
Old 06-15-2010, 11:42 PM   #3
sofiagonza
Member#: 193535
Default congratulation
congratulation................waoooo
how was the ETG on full load and full boost?? i'm looking for a HTA68 , could you give me the hta68's spec like: compressor and turbine inducer and extucer. In the HTA68 is the turbine housing a TD05H ? is a 7cm or 8cm.
Thanks a lot for your help....
sofiagonza is offline   Reply With Quote
Old 06-15-2010, 11:44 PM   #4
thorne
Member#: 130063
2003 WRX
Silb
Nice. Congratz on the numbers. I had so wanted an HTA68 for my 2.0. I think its the ideal turbo for it.
thorne is offline   Reply With Quote
Old 06-16-2010, 12:08 AM   #5
rubinm
Member#: 63483
2005 STi HTA68'd+e85
Nice! thats a fun setup right there
rubinm is offline   Reply With Quote
Old 06-16-2010, 12:17 AM   #6
KurtP
Member#: 44836
1999 Fozzy
do you see EL headers make a significant difference on the 2.0's in terms of spool up?
KurtP is offline   Reply With Quote
Old 06-16-2010, 03:50 AM   #7
socalLGT
Member#: 89752
08 STI
You can find information about the FP HTA68 here: http://store.forcedperformance.net/m...Code=WRX-Turbo
I'm an EL header fan in general. They will improve spool a little bit, but the difference is certainly not earth shattering. They will definitely bump up the midrange torque and help the top end breath better as well.
socalLGT is offline   Reply With Quote
Yimi Sport Tuning: 2007 STI, stock motor, 20G + E85 = 452whp/487wtq! socalLGT Proven Power Bragging 229 07-08-2012 02:38 PM
YimiSport Tuning: 05 STI, stock turbo, 91 octane only: 325whp/360wtq paul@YimiSport.com Proven Power Bragging 52 06-15-2010 01:00 PM
Tuning: 05 STi EQ tuning stage 1 built motor, stock turbo, 91 octane OBrex05 Proven Power Bragging 5 03-18-2010 02:45 AM
GT35r/DPR stage 4 AVCS cams/Built motor..91 Octane MARKGSTI Proven Power Bragging 84 11-15-2005 08:35 PM
would my WRX run different on 91 octane rather than 93 mcu81 Service & Maintenance 16 11-26-2002 05:21 PM
