Old 06-15-2010, 06:15 PM   #1
gloyale
Member#: 134923
1989 GL w/96 EJ22
Default Code 0180? Fuel Temp sensor circuit?
Hey all.
Run into a new problem. Sorting out the last bits of my EA to EJ convesion. Got the OBD II connector hooked back up. Scanned codes.
Got a p0180......Fuel temp sensor circuit.
Problem is, the ECU, Harness, Engine and everything are from a 96 Outback, MT, 2.2. I don't think it had a Fuel Temp sensor.
all the charts and diagrams I've seen show the Fuel Temp sensor as a 1.8 only.
Anybody got ideas?
gloyale is offline   Reply With Quote
Old 06-17-2010, 12:02 AM   #2
gloyale
Member#: 134923
1989 GL w/96 EJ22
Solved
There indeed was a fuel temp sensor circuit. At least a wire at the pin.
Pinout chart said it should measure 2.8 to 3.4 volts key on, 77 degrees outside.
I measured it and it read about 5-6ish, don't recall excactly.
So I took the wire and soldered in a 270 ohm resistor on it in series to ground. Volts dropped on the pin to about 4.5
So I added in more resitors in series until I got the measurement to just under 3 volts.
Took 4, 270 ohm resistors to get there.
Cleared codes and bang, check engine light off for the first time since installation of the EJ engine (about a month)
I didn't like all the resitors in series, so I just went to radio shack and got a 1k ohm resistor (1/2 watt rated) and put it in instead. Works
So there you go eveybody.......1k resistor tricks the Fuel temp circuit FTW
Old 06-18-2010, 03:32 PM   #3
gloyale
Member#: 134923
1989 GL w/96 EJ22
Oh, Also I forgot to mention the pin for the fuel temp sensor ciruit is 25, a red and Green? striped wire.
Old 08-05-2010, 08:22 PM   #4
subbieedude!
Member#: 220033
thankss. this hopefully solved my problem as well. i got the same code cuz i swapped a 2.2 ecu and motor into my car this is the only code that holds me from my inspection sticker.
subbieedude! is offline   Reply With Quote
Old 03-24-2013, 03:02 PM   #5
kanurys
Member#: 260111
Nice find. I did some measuring and found a 1.2k resistor did the trick for a '99 phase II 2.2.
kanurys is offline   Reply With Quote
Exhaust gas temp sensor circuit high (p0546) johnny11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-07-2007 05:25 PM
03 fuel temp sensor? EJ20 Swap code Costas Subaru Conversions 3 12-19-2004 11:49 PM
P0453 code EVAP Fuel pressure high circuit pitcrew Subaru Conversions 0 08-17-2004 10:08 PM
P0183 Fuel Temp Sensor A Help Kevin Thomas Normally Aspirated Powertrain 7 11-25-2003 10:26 AM
CEL, Fuel Temp Sensor?? fastsubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-14-2003 04:53 PM
