Old 06-15-2010, 09:15 PM   #1
Keiji22
Member#: 175854
98.5 Volvo V70 XC
Bleached Sphincter
Default 92 Legacy L 2.2l AWD AT: AC and Engine Issues
Specs:
1992 Subaru Legacy L 4-door
Automatic Transmission - Full Time 4WD (AWD)
2.2L H4
Hey everyone. A few Issues on this scoob.
The car itself has 241k. Unknown on the engine.
Axles are going, I can fix those.
But the engine runs like crap... sometimes.
On a cold start, or after leaving it sitting for a few hours, the engine starts up fine, and runs like a champ.
On a warm start, after turning it off, going inside for a few minutes or more, the car throws a CEL (Non disernable after trying to do the hook-up diagnostic... the LED on the computer box is busted) and runs rough. The idle goes up and down and up and down, fluctuating between 100 and 1000 RPM, shaking wildly. If I rev the engine above 1500RPM, it runs smooth and fine, but the CEL is still on.
Spark plugs are all new. Belts are all new. Had a 100K service done to it in January, but the problem existed before all of this.
Any ideas?
On that note, my AC Condenser is frozen solid. Other than buying a $300 AC Unit to replace it, what are my options? I currently have the belt off of the pulley (I was eating up belts before hand) and tightened properly to run everything but the AC.
Thanks a bunch!
Keiji22 is offline   Reply With Quote
Old 06-15-2010, 09:53 PM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Rough idle can be the cause of many things. It would help sooo much if you could diagnose the CEL. Check your MAF sensor, make sure it is still in working order. Check your TPS, make sure it is functioning properly. Also check the Idle Air Control Valve located on the left side of the intake manifold. Check all vacuum hoses. Try to get the CEL diagnosed, that will help you out the most. Hope this helps.
Jessekrs123 is offline   Reply With Quote
FS: 92 Legacy L wagon 5spd AWD Blue Cheap (PICS) Dealer Xing Tri-State Area Forum 25 04-27-2005 11:51 PM
FS in NJ, NYC: 92 Legacy L wagon 5spd AWD Blue Cheap (PICS) Dealer Xing Private Vehicle 'For Sale' Classifieds 0 04-16-2005 12:07 PM
('93-'01) Easiest way to make a 2.2l AWD Legacy faster BulletRide Impreza Forum 3 02-15-2005 03:49 AM
('93-'01) Differences between 1.8L & 2.2L AWD Impreza 95+ Subdued Impreza Forum 26 05-13-2003 08:40 AM
My 1995 L - 2.2L - AWD JPWM Member's Car Gallery 20 06-04-2002 03:06 AM
