Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 06-16-2010, 04:27 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default PERRIN Suspension Parts Buyer Guide
At PERRIN Performance we care enough about YOU, to put extra effort into our products and services, insuring you get the absolute best part at a great price. Drawing feedback from our past clientele, we continually review and revise our products to make them the best choice available on the market today!
We are extremely proud that most PERRIN Performance products are Made In The USA. While this does create a challenge for cost vs. goods made by our competitors overseas, we strongly believe it is the correct thing to do! Thus supporting the American economy with the use of raw materials and even more importantly labor! Keeping American’s at work is good for ALL aspects of the industry and economy. Help us in supporting the USA and buy PERRIN brand performance parts for your Subaru!
We carry a wide variety of the "bread and butter" parts that make your Subaru perform! Want to make an even larger jump in performance? Then check out our specialty parts such as PSRS, Cross Lock and Package Deals. We also cary the full H&R Suspension line. Read on to see what we have for your Subaru!
Sway Bars
The first suspension modification we recommend is a set of stiffer sway bars. If the budget is limited we recommend at minimum a rear sway bar upgrade. In short a sway bar upgrade will keep the car flatter during a corner allowing the tires to use all their grip to get you around the corner. Sway bars are also used to "tune" the handling of your Subaru, you car is set up from the factory to under steer quite a bit. Fit a stiffer rear sway bar and you will reduce the under steer to a near neutral set up, perfect. PERRIN sway bars have multiple end link mounting positions to allow for fine tuning of the bars effectiveness. There is a lot of information and lots of different sway bar set ups so we urge you to click below to read more on the PERRIN web site.
Click Your Subaru Below To See What Sway Bars Are Available
2002-2007 WRX
2004-2007 STI
2008-2010 WRX
2008-2010 STI
Stiffness chart for 2002-2007 WRX Rear 22mm & 25mm Vs. Stock.
Stiffness chart for 2008-2010 WRX & STI Rear 19mm & 22mm Vs. Stock.
Strut Braces
The PERRIN Performance Front Strut tower Brace does two things REALLY WELL 1.) Stiffens up the front suspension by bracing the front strut towers against each other to counteract chassis flex. 2.) They look really cool with the cast end feet and wrinkle powder coated cross bar, available in Black or Red.
Click Below To Check Them Out On The PERRIN Web Site
2002-2007 WRX & STI
2008-2010 WRX & STI
Let us know if you have any questions.
More Coming ....
PERRIN is offline   Reply With Quote
Old 06-16-2010, 04:28 PM   #2
PERRIN
NASIOC Manufacturer
Member#: 6776
Control Arms / Lateral Link Set
Add strength, adjustability, durability and awesome looks. The PERRIN Performance rear control arm/lateral link set will do all of this and then some. Made from 6061 aluminum and featuring TeflonŽ-lined rod ends & delrin bushings our PERRIN Performance Control Arms allow camber adjustability and significant strength over the weaker OEM units. This item fits the 2004-2007 STI and will fit the 2002-2007 WRX if STI rear sway bar and endlinks are used.
Control Arms / Lateral Link Set For 2004-2007 STI
End Links
Sway Bar End Links connect the end of the sway bar to an unsprung point of the suspension (usually the control arms, spindle or lower shock/strut body) transmitting the sway bars force to the suspension. OEM end links are designed "just enough" for weak OEM sway bars. add a larger, stronger & stiffer aftermarket sway bar and the OEM end links will not hold up. Depending on the link they will, bend (reducing the sway bar effectiveness) or brake! (eliminating the sway bars effectiveness). In short, if you up grade your sway bars, up grade your end links.
Click Your Application Below To Check Them Out On The PERRIN Web Site
Front End Links - All 2002-2010 WRX & STI, All 2005-2009 Legacy
Rear End Links - 2002-2007 WRX
Rear End Links - 2004-2007 STI
Rear End Links - 2008-2010 WRX & STI
Old 06-16-2010, 04:28 PM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
P.S.R.S. - Positive Steering Response System (ALK - Anti Lift Kit)
Our P.S.R.S. system improves:
>Steering response in corners by adding additional caster angle
>Straight line performance by preventing lift when accelerating
>Stability by eliminating the squishy factory rubber mount
Added Benefit:
The increased width of plus size wheels & tires adds enough leverage over the factory rubber mounts to literally pull the car side to side on uneven or rutted roads. This is extremely unnerving and can be completely eliminated with our PSRS system.
Want a little less NVH?
Impreza owners that want the increased caster angle but want more compliance in the ride can use the optional Urethane Bushing Set. Available for 2002-2007 Impreza, WRX & STi.
Click your Subaru below to check out the P.S.R.S. for your car.
2002-2007 WRX & STI
2008-2010 WRX & STI
2005-2009 Legacy
We also have a "Zero Caster" unit that has the benefit of a solid bushing without the added caster. Can be installed without getting an alignment after. This is available for 2008-2010 WRX STI & 2005-2009 Legacy.
PERRIN Cross Lock Brace In Stock
Reduce flex and stiffen up your front sub frame.
Old 06-16-2010, 04:31 PM   #4
PERRIN
NASIOC Manufacturer
Member#: 6776
Save for future use
Old 07-04-2010, 09:44 AM   #5
IMPREZive 02 WRX
Member Sales Rating: (17)
Member#: 11436
1999 Impreza RS
eBay racing edition!
Does the 25mm front sway bar fit WRX wagon or more specifically a swapped RS with Legacy turbo crossmember? I'm looking for a good match for my Perrin 25mm rear bar.
IMPREZive 02 WRX is offline   Reply With Quote
Old 07-04-2010, 12:52 PM   #6
PERRIN_Adam
NASIOC Manufacturer
Vendor Sales Rating: (0)
Member#: 247558
2013 STI H/B
Thanks for asking! The 25mm front bar should fit just fine. As long as you have a turbo motor in the car now, there will be adequate clearance.
Plus this weekend they are on sale www.PERRINPerformance.com !!!
Let me know if I can help further!
PERRIN_Adam is offline   Reply With Quote
Old 07-04-2010, 01:34 PM   #7
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
Awesome. I got a pretty good quote from a vendor here, so I'll compare it to your price with the discount code. Either way, I'm ordering now.
Old 07-04-2010, 01:53 PM   #8
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Rock on! WE look forward to processing your order ASAP! Thanks again!
Old 07-04-2010, 03:42 PM   #9
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
Right you are! The 4th of July discount code can't be beat! I look forward to the next autox with my new Perrin FSB!
Thanks for your assistance.
Old 07-04-2010, 06:03 PM   #10
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Never a problem at all! Thanks again!
Old 07-20-2010, 02:36 PM   #11
PERRIN
NASIOC Manufacturer
Member#: 6776
Everything In Stock & Ready For Your Subaru!
Old 07-20-2010, 05:46 PM   #12
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Great price! Great Parts! Inventory on hand and ready to ship! Most orders ship same day!
Old 07-24-2010, 06:35 PM   #13
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Bump!
Old 07-26-2010, 12:14 AM   #14
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
JULMAS is still in effect!
Old 07-28-2010, 06:17 PM   #15
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Old 08-01-2010, 04:39 PM   #16
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
PERRIN SwayBars, Endlinks, Springs, and More!
Adam @ PERRIN Performance
Old 08-17-2010, 06:19 PM   #17
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Great information here about PERRIN Suspension Products including Sway Bars, PSRS / Anti-Lift Kits, Bracing, Endlinks, Control Arms and More!
Old 10-18-2010, 04:34 AM   #18
kirbwrx
Member Sales Rating: (25)
Member#: 110450
2007 Spec.b Refugee
284hp 320tq Cobb Tuned
Any idea if the newer WRX/STI strut bars fit the 05-09 legacies?
kirbwrx is offline   Reply With Quote
Old 10-18-2010, 02:36 PM   #19
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Thank you for asking! The bar feet, might work just fine. But the bar is unlikely to work. Sorry!
Old 03-24-2011, 11:12 PM   #20
STGuy
Member Sales Rating: (5)
Member#: 262734
2004 STI
will the front end links work with the oem sway bar? im goin to order one soon just didnt have the funds for the sway and links at the moment
STGuy is offline   Reply With Quote
Old 03-25-2011, 12:11 PM   #21
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Yes! Absolutely they all work with the OEM parts!
Same with the bars. They work with the OEM Endlinks too.
Hope that helps! Please let me know how I can help in anyway further!
Adam @ PERRIN
Old 03-26-2011, 06:10 PM   #22
wrx yo
Member Sales Rating: (2)
Member#: 231825
2011 WRX YO
Hey Adam,
You should update for the 2011's
Also can you guess get me a silver sway bar? going with silver intercooler and intake would be nice for it to match the rest of my engine Sorry i am ocd
wrx yo is offline   Reply With Quote
Old 03-30-2011, 08:38 PM   #23
PERRIN_Adam
NASIOC Manufacturer
Member#: 247558
2013 STI H/B
Originally Posted by wrx yo View Post
Hey Adam,
Thanks for asking
STI Parts 2011 CLICK HERE
WRX Parts 2011 CLICK HERE
The bars are only in red and black. But can easily be painted silver. Just a thought! (Actually the Black Strut Bar with the Silver Feet would look nice!)
Thank you!
Old 06-06-2011, 10:57 AM   #24
CARVtech
Member#: 284878
0108 01 WRX & 08 STi
WRC Blue
Hello,
can you please supply me a quote to my e-mail account or PM.
2001 GDA WRX.
SET: Rear Pillow Ball Lateral Links.
SET: Rear Pillow Ball Trailing Links.
I need something of very good quality as this is a RWD only very high torque project
CARVtech is offline   Reply With Quote
Old 06-06-2011, 05:51 PM   #25
PERRIN_Chris
Member#: 186665
2014 BRZ
Carvtech,
We have PERRIN STI rear lateral links. They are designed to be used the an STI rear swaybar and endlink only. I'll send you a price to you via PM. They should be able to handle your project, we these on a local drag car running over 600WHP!
PERRIN_Chris is offline   Reply With Quote
Brand new Perrin suspension parts for sale Arch26 Suspension/Brakes/Handling 8 06-05-2007 03:34 PM
buyers guide for 2.5RS vintagemilano Newbies & FAQs 9 08-02-2005 08:15 PM
"WRX parts buyers guide - WRX Blow-Off Valves" windfactory Car Part Reviews 5 09-18-2002 06:57 AM
"WRX parts buyers guide - WRX Exhausts" windfactory Car Part Reviews 0 08-15-2002 03:40 PM
Link to Car Sounds on-line buyers guide dbrown Car Audio, Video & Security 0 03-07-2001 02:09 PM
