Old 06-16-2010, 06:15 PM   #1
PSM_02_WRX
Member#: 197108
2003 Ford Mustang GT
Default Car shakes slightly when shut off
I believe this could be my motor mounts, other say bad gas. What happens is I turn the key off after it runs and it shakes slightly. If anyone has seen a Diesel truck it shakes when shut off, that's what my car does. I have both diesel truck and Subaru so its easily comparable. Anyone know any reasons why the car would do this?
PSM_02_WRX is offline   Reply With Quote
Old 06-16-2010, 06:19 PM   #2
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Is it a noise or can you feel it shaking while you are in the car or both?
Jubert69 is offline   Reply With Quote
Old 06-16-2010, 06:21 PM   #3
PSM_02_WRX
Member#: 197108
No noise, just like after I turn the key off and car shuts off. Its not a violent shake but its noticeable.
Old 06-16-2010, 06:21 PM   #4
bugeyerex02
Member#: 195967
2002 VF39'd WRX
WR Blue
i get the same thing. it sort of feels like the car is dieseling when it shuts off. from what i understand its normal, unless someone here corrects me.
bugeyerex02 is offline   Reply With Quote
Old 06-16-2010, 06:31 PM   #5
Jswansti
Member#: 239623
2006 Impreza STi
The same thing happens to my car when I shut it off. Can just kind of feel it shaking/vibrating in your seat a little when you turn it off. I think it's pretty normal.
Jswansti is offline   Reply With Quote
Old 06-16-2010, 06:33 PM   #6
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Same thing happens on mine. I have a TT so I've opened my hood and watched my car turn off. The motor pitches a bit but I don't think it's too bad. New motor mounts are on my to-buy list, but not because I think the stock ones are bad or anything. I just want them.
Punk In Drublic is offline   Reply With Quote
Old 06-16-2010, 09:08 PM   #7
JustinM88
Member#: 156688
2007 WRX TR
Urban Gray Metallic
Mine does this too. I kinda like it though
JustinM88 is offline   Reply With Quote
Old 06-16-2010, 09:19 PM   #8
TheStigg
Member#: 215003
2004 WRX
JBP
I have the same issue, but i have bad motor mounts. Everytime I shut the car off, it shakes and sqeeks. Bad motor mounts ftl!
TheStigg is offline   Reply With Quote
Old 06-16-2010, 09:45 PM   #9
SLIC VIC
Member#: 187428
2006 WRX Limited
my '06 used to shake a bit when the motor was cut off, and my mechanic mentioned my mounts were cracked. Replaced with Group N mounts and i dont feel any shaking....could be the problem your having?
SLIC VIC is offline   Reply With Quote
Old 06-16-2010, 10:52 PM   #10
gmv4
Member#: 248784
2010 WRX Limited
SSM
what octane gas are you using? If the engine is running for significant time 3+ seconds after you turn the ignition off then the gas is detonating without spark (dieseling). The engine in my car has shaken a little bit (not running tho) on shutdown since it was new. . .just the boxer way i guess. . .
gmv4 is offline   Reply With Quote
Old 06-16-2010, 10:53 PM   #11
Trigun001
Member#: 107092
2005 WRX Evo3 16g
Platinum Silver Metallic
they arent bad motor mounts they are just the standard elasticity of the subaru motor mounts. If you dont like the shaking (I didn't) go buy yourself a set of harder mounts for the engine and tranny. Next time you need a clutch or timing belt ask them to swap the mounts. Note that you will have increased NVH and for me this was my loudest upgrade.
Also there is literally zero chance that anyones cylinders are hot enough on shut off to get the gas to "diesel" I'll go into the math if anyone wants me to but really you will rarely see dieseling in a non diesel engine.
Trigun001 is offline   Reply With Quote
Old 06-16-2010, 10:56 PM   #12
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Your engine mounts are shot. Replace them with Group-N's and be done with it.
Old 06-17-2010, 04:28 PM   #13
SLIC VIC
Member#: 187428
2006 WRX Limited
i always thought the detonation after the ignition ("dieseling") is cut was on carberated engines only due to the fuel system running on vacuum rather than your injectors and fuel pump? i could be wrong ::noobie voice::
Old 06-17-2010, 05:48 PM   #14
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
You are correct.
Vibration when you shut the car off is normal.
CKxx is offline   Reply With Quote
Old 06-17-2010, 06:55 PM   #15
bryantkalagian
Member#: 226391
01 Silverado
It's because you have horizontally opposed cylinders.
bryantkalagian is offline   Reply With Quote
Old 06-17-2010, 09:11 PM   #16
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Not necessarily. I have near-new Group N mounts and I still get the shaking
Audiosavvy is offline   Reply With Quote
Old 06-17-2010, 11:50 PM   #17
miketheskibum
Member#: 244892
2001 Outback Limited
I'm pretty sure it's normal. When a cylinder moves towards one side of the engine, it pushes the engine the opposite way. When the engine is running, it just shifts on top of the mounts, and before the force can be transmitted through the mounts to the frame, the engine will move in the opposite way, correcting the vibration (this is due to the horizontally opposed cylinders). When you turn the car off, the engine slows down so that it cannot correct the vibration before the momentum is transferred to the frame, so the car shakes back and forth a little. I don't KNOW any of this, but it makes sense in my head. *shrug*
miketheskibum is offline   Reply With Quote
car shaking/vibration when brake twlai Brakes, Steering & Suspension 18 02-03-2012 03:55 AM
Car shakes violently when letting off gas at 5k rpms? Help... ImportVenom Transmission (AT/MT) & Driveline 9 10-21-2011 07:16 AM
Rattle when shutting off car jahl7787 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-23-2007 02:27 AM
engine shakes alot more when shutting off ocorzo Other Engine Management 4 10-24-2006 12:02 AM
