Old 06-22-2010, 06:39 PM   #76
Dave D.
Member#: 130990
06 Red Wagon hta68
MPS tuned JDM 6-speed
Originally Posted by rexblake View Post
As for pump gas, I can't seem to find the thread I'm looking for. Some guy that was running a 68hta on a built (I think) 2.1L, had issues, Dom put on a 10cm hotside, retuned, gained 30whp on pump. Although, it still looked like it was losing power by the 8k redline. Ring any bells? Someone point me in the right direction?
It's in the Built Motor forum:
http://forums.nasioc.com/forums/show...hlight=stroker
Dave D. is offline   Reply With Quote
Old 06-22-2010, 08:42 PM   #77
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Originally Posted by LittleBlueGT View Post
FWIW I have a couple of logs showing 370+ airboy whp on a HTA68 on E85.
If they have not been posted up on the road dyno thread for all to see, then it didn't happen - anyone can say they have a log where they made XXXwhp, but unless they post up, it is a worthless statement
Second post down the page. 411 at the wheel. Again, I contribute this completely to a high reading dyno, but hey, there's a dyno of it.
And that right there is the real problem. If it is on a dyno sheet it must be true. Not having a go at you mate, but this attitude needs to stop. It does wonders to sell products, but it does nothing for the hundreds/thousands of customers who spent their hard earned cash on a turbo expecting it to perform like a turbo making these numbers and it doesn't.
A 411whp full weight 3500lbs WRX/STi should trap at least 120mph - most HTA68 WRX's are lucky to break 105mph, and that right there says <300whp.
Leslie
wrxsti.l is offline   Reply With Quote
Old 06-22-2010, 09:30 PM   #78
LittleBlueGT
Member#: 96204
2005 Legacy GT
Atlantic Blue
Why are you arguing with me?
I can't get my hta68 to respond that well, but I did just post the log 3 posts ago. I have to post in the data log thread for it to be worthwhile? What is wrong with this thread? At any rate, I don't have the specifics on tire size etc... but when I did plot it a few months ago with very conservative numbers for the values I wasn't 100% sure of it was 370+ whp. The guy that tuned it said he got 400 on the airboy. Either way you can tell by the log that decent power is being made. I am sure we can both get a pretty good idea of power when we consider boost, timing, even if the MAF wasn't scaled perfectly you tell from the log that good power is being made.
FWIW I can't seem to get much more then 18 psi (at red-line) out of my 68HTA in the summer heat, but in the winter I can hit a bit higher.
The best I did in the cold (and it gets colder, just haven't logged yet in -20F weather) was 4.74 MAFv on a KSTech 73 mm intake.
LittleBlueGT is offline   Reply With Quote
Old 06-22-2010, 11:31 PM   #79
rubinm
Member#: 63483
2005 STi HTA68'd+e85
Leslie
pump gas or e85?
perhaps im lucky but i trapped 107mph at Pueblo CO, (4900ft - greasy track) Full weight STi-
NHRA's official Altitude correction factor for that track is 1.0466
so 107 x 1.0466 = 111.98 mph.
and the official correction factors link: http://www.nhra.net/tech_specs/altitude.html
rubinm is offline   Reply With Quote
Old 07-27-2010, 03:48 AM   #80
Overboosting04
Member#: 202417
04 WRX
EJ207/Rotated/E85/6spd
I know this thread is kinda dead but ive gotta pipe in, the hta68 is a great turbo for the 2.0, Ive got a ej207 that made 326whp on only 22psi on e85 and couldve made 300whp or close to on 93 but didnt care enough because the car was going to only run on 93 in case of an emergency. I was maxing out the 65mm intake on only 22psi so I bought the ks-tech 73mm intake and got it streetuned on 24psi, dont have any new numbers, but should the tuner said it should be around 350ish-whp on a mustang. My next plans are for a external wastegate and a 8cm housing for even more top end. Anyway heres the graph for the old tune
Overboosting04 is offline   Reply With Quote
Old 07-27-2010, 04:46 AM   #81
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
Originally Posted by jason miller View Post
Really, the stock ej205 heads/cams aren't designed to make a lot of top end. Pretty much any setup is going to taper a bit up top, unless you're running such a big turbo that it's not fully spooling until almost redline.
worrdd^^^
heres a link to my thread.... product of stock ej205 heads on ej257block/hta68 8cm
http://forums.nasioc.com/forums/show....php?t=2020764
im losing 15hp up top more than what id like.. it be nice to hold 300 to redline......at least.
im buying some ej205 heads and boring em out on the side.. 272 cams ontop of that.. aiming for 350awhp.. made 320 with my stock heads a month ago hta68 8cm.. =D
Flyin_Hayn is offline   Reply With Quote
Old 07-27-2010, 04:58 PM   #82
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
Makes me wonder what I should do with my new hta. Its going on a fully built 2.0. Heads were ported polished gsc 272, pistons rods. I'm thinking of getting bigger hot side.
karlknaupp is offline   Reply With Quote
Old 07-27-2010, 05:47 PM   #83
rexblake
Member#: 178426
2010 Evo X MRt
Def get a bigger hotside. You will want it with that much headwork. I'd even go so far to say you may want a bigger turbo...
rexblake is offline   Reply With Quote
Old 07-27-2010, 10:36 PM   #84
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
Yea that's what I'm thinkin too. Also went over sized valves too. Ill be running e85.
Old 07-28-2010, 04:41 PM   #85
xandi911
Member#: 163991
I
Leslie
maybe you are a little bit wrong my friend... should trap? YES IT TRAPS.
360whp WRX FULL WEIGHT
xandi911 is offline   Reply With Quote
Old 07-29-2010, 01:20 AM   #86
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
nevermind, not worth it.
Concillian is offline   Reply With Quote
Old 07-29-2010, 02:09 AM   #87
rexblake
Member#: 178426
2010 Evo X MRt
Leslie
I agree. That's why I posted it. However, I don't see this one random "411whp" dyno pull any different than the higher reading vf39 or 16/18/20g pulls I have seen on a dyno. I personally believe the 411whp pull on MAP's dyno is complete and utter BS. No doubt in my mind.
Not only do I have personal experience with MAP as a business (**** would be the appropriate word here, I have never experienced such horrible customer service in all respects, including sending me the wrong parts I personally called in to order), but I have also heard stories of people going to dyno shoot out days there and making astronomically higher numbers than they precisely experienced. And to think that the thread was started by an employee of MAP.... They clearly have other motives for providing huge dyno numbers.
Regardless, the 68hta is great, for stock 2.0 heads. If someone starts throwing headwork into the mix, it's not a very good turbo. A larger hotside is mandatory (from the 7cm) and I'd even go so far as to say a larger turbo is needed.
I ran the 68hta with my headwork (bc valvtrain, 272 cams), on pump it sucked donkey balls, with E85 I made 80whp more than my small 16g and spooled the same. Boom. This is a great turbo for stock heads and high octane (it needs high octane). However, with headwork I was losing all power by 6500rpm. Hence why I now have a dom 3xt-r. I wait for the power but it provides a longer rpm power band.
Old 07-29-2010, 11:23 AM   #88
Crimeboss
Member#: 232043
2005 WRX
I agree with that statement. It took me a large top mount and meth to make mine do anything worth while. I am sort of bummed with regard to the headwork making the power suck. Guess I'll have to rethink my hybrid strategy if my 2.0 goes pop as I was thinking of doing machining and cams.
Crimeboss is offline   Reply With Quote
Old 01-29-2012, 11:18 PM   #89
smadasam
Member#: 161271
2005 Saab 92x
+1 for hating on the FP 68HTA (I have one)
I started with a stock '05 ej205 and a Evo3 16g. I made about 280+ whp before I spun my rod bearing.
Next I had Maxwell power rebuild my engine as a 2.1 stroker with some head work. This was a little over two years ago. I figured I would get a new turbo for the new build, so the 68HTA seemed like a good fit for my daily driver needs. I have been regretting that decision ever since then. After my new motor was broken in, I was only hitting about 290 whp on pump gas. Dom at MPS thought that there was too much restriction in the exhaust system. We tried a diffrent turbo back and broke 300 whp. Finally we ordered a 10cm hotside from Blouch, and made it to 330 whp and called it good. I think he left it at 22 lbs boost. Needless to say, I was kind of disappointed. At the time, Dom felt like we would have done much better with an 18g. At the time I called up FP and complained. There was no way that turbo could flow 47lb/min. The support guy claimed it would at 30+ lbs, but I thought that was BS and I am very doubtful it could perform as advertised even with race gas. At least I don't have to worry about breaking my 5 speed for now, but since I am keeping my car forever now, I figure I might as well get a better matching turbo for my build.
I would love to see some dyno posts of a 18g xt on a 2.1 stoker.
Here is my dyno plot from Maxwell Power's dyno.
smadasam is offline   Reply With Quote
Old 12-04-2012, 04:54 PM   #90
Dave D.
Member#: 130990
06 Red Wagon hta68
Back from the dead. Did end up making 387/411 with the '68 on a built motor, on 92 pump. Timed a 5.4 sec 50-100 run. Since then I blew my tranny, have just had a jdm 6-speed installed, along with bigger injectors and an ETS IC. Scheduled for a retune on the 11th this month. With the colder weather can I break 400whp on pump?
We'll see. Not that it really matters anymore. The hta68 is discontinued, and when I get a little more cash put aside I'm probably going to get myself a 20g-xt. Will anyone even want to buy my old turbo at that point?
Old 12-04-2012, 05:27 PM   #91
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Put a price on it.
Zee Biker is online now   Reply With Quote
Old 12-04-2012, 07:14 PM   #92
Dave D.
Member#: 130990
06 Red Wagon hta68
Originally Posted by Zee Biker View Post
Put a price on it.
Well said. Hopefully by this summer.
Old 12-04-2012, 09:38 PM   #93
thisisntjared
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
Yours is the best I have seen from the hta68:
http://forums.nasioc.com/forums/show....php?t=2312472
sorry about the tranny though... but in your first post you totally called it. do you have a dyno plot of what the curve looks like?
thisisntjared is offline   Reply With Quote
Old 12-05-2012, 01:25 AM   #94
Dave D.
Member#: 130990
06 Red Wagon hta68
It was posted, but I stopped paying my GoDaddy extortion fee a few months back. I'll look for a place to rehost it. I think if I renew my NASIOC supporter membership I can post some pics here.
Old 12-05-2012, 12:55 PM   #95
Dave D.
Member#: 130990
06 Red Wagon hta68
Silly double post.
Old 12-06-2012, 03:55 PM   #96
Kastley85891
Member#: 127704
2013 Leggy
Scooby no4 - huntin for 5
18GXT all day, on the EJ20 run a 20G,its not too large on a 2.0, its dam good fun and with the right parts / tune can spool very well,especially on E
Kastley85891 is offline   Reply With Quote
Old 12-10-2012, 09:07 PM   #97
josedwrx
Member#: 199988
2002 wrb bugeye
vf39 12.6 @110
^What 20g would you recommend? Is the xt-r worth the extra money? Im at a toss up between the 18gxtr and the 20gxtr. Haven't heard too many people running the 20gxtr's on the 2.0l.
josedwrx is offline   Reply With Quote
06 WRX Blouch EVO 3 w/ 8cm vs TD05-18G XT which one? konmann Factory 2.5L Turbo Powertrain 12 06-14-2010 12:39 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain 103 03-11-2010 01:41 PM
FP 18g vs Blouch 18g futurestiguy Factory 2.5L Turbo Powertrain 46 04-14-2009 06:22 PM
what has more top end, pe1820,or 1825? kenlee Factory 2.5L Turbo Powertrain 15 06-09-2004 12:34 AM
S-AFC vs. Chip which has more hp gains? Cusco Normally Aspirated Powertrain 0 01-30-2002 07:38 AM
Message Board Statistics All times are GMT -4. The time now is 11:32 PM.
