Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-17-2010, 02:02 AM   #1
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
Default Mystery alert! bizarre dome light issues.
Hey Everyone heres the situation:
05 Forester
Automatic
80,000 km
non turbo fully loaded.
The issue is that the "door ajar" light on the gauge cluster stays on ALL THE TIME. it wont turn off. even when the car is parked in the garage and the key is out of the ignition. it is bizzare because the dome light works perfectly. it functions properly when each door is opened.
*other than removing the bulb* does anyone have any idea how to fix this? or what could even be causing it? does anyone have a wiring diagram for the gauge cluster door ajar light circuit?
Thanks!
Loomin is offline   Reply With Quote
Old 06-28-2010, 09:59 PM   #2
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
bump!
Old 07-01-2010, 01:44 PM   #3
littlewhitewagon
Member#: 103068
11 STI sedan
Sounds like you have a short in the cluster wiring harness. Pull the cluster and start looking behind there. You may also need to get a hold of the service manual and diagram to start troubleshooting where the short is if it isn't obvious.
Did you install or change something in your car recently?
littlewhitewagon is offline   Reply With Quote
Old 07-01-2010, 02:53 PM   #4
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
nope. its bone stock. not a single mod.
ill check behind the cluster. ive heard of rodents getting into the engine bay because its warm. they chew up wires and hoses etc. i doubt it could get into the car though.
Old 07-01-2010, 03:24 PM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I'm not sure but the door indicator light may be a LED and not a bulb. If there is a indicator for each door I suggest you check the wiring that door and the switch to it. There could also be a problem with the driver board in the cluster that controls the lamp. Hopefully that isn't the case.
Old 07-02-2010, 03:37 PM   #6
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
ahh, its only one light i think. has anyone else had this problem before? ill try to post a picture of the cluster with the light on. i was thinking of removing each door switch individually and seeing if the light turns off. hopefully by unplugging the switch it will open the circuit and we will find a broken switch that is stuck "on" or something. wouldnt that be a nice simple fix haha
Old 07-05-2010, 09:22 PM   #7
littlewhitewagon
Member#: 103068
11 STI sedan
The door switch is not likely to be the problem since you stated that the dome light functions normally. It's worth a try, but I really don't think that is the issue. Don't forget about the rear hatch, it should be on the same circuit and the switch is in the latch assembly.
Old 07-06-2010, 03:35 AM   #8
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
ah yes thats a good idea. definately something to check. havent had any time to check it out yet.
DIY Dome Light Modification bike867 Interior & Exterior Modification 7 06-17-2010 04:03 PM
LED SMD Board for Dome Light and Map Light, LED License Lights, JDM Air Fresheners Exclusive Mods NWIC Vendor Classifieds 2 06-04-2010 04:48 PM
LED SMD Board for Dome Light and Map Light, LED License Lights, JDM Air Fresheners Exclusive Mods Interior/Dressup/Audio & Security 2 06-03-2010 02:21 PM
Dome Light issue in my 02 wagon CodeBlue Electrical & Lighting 11 05-22-2010 02:52 AM
dome light mystery, 97 WRX wagon redsunsfd Electrical & Lighting 1 12-21-2007 07:19 AM
