Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Non-Subaru Stuff
Old 06-17-2010, 10:24 AM   #1
subygirl
Member Sales Rating: (9)
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Default 1988 Mazda 323 GTX complete part out
12/31/15 UPDATE: I want this car and parts gone before we have to move again. We are accepting offers on the whole lot of loose parts and the parts car. We will consider all offers. Parting this out got pushed to the back burner for a few years which is the reason for the lull
This is an updated list as of 4/12/12!
Our GTX sold last year, but we still have the parts car sitting around. Car was hit in the rear, but there is minimal damage except for the wrinkle in the frame at the doors.
We have brought a slew of parts back from VA and are now housed in our garage. The parts car is still available to be purchased as a whole for a now discounted price, and does include some extra parts we couldn't bring back with us.
Loose parts in IN Some stuff has prices with it, others we are still researching current market price - feel free to offer
We now have a set of mint conditions front seats here in Indiana! No rips or tears. Not worn out. Both front seats are $600 obo
Gas tank - $100
Gas filler neck - $50
Head with cams
Miata automatic pistons (gives gtx higher compression) & 2 gtx pistons –
Steering column controls -
Stock turbo with cracked manifold and some shaft play–
Complete injector harness –
Passenger side slightly rusty motor mount –
Top transmission motor mount good shape –
8 used hydraulic lash adjusters –
starter –
New old stock drivers door seal in factory bag -
Stock BPV
Top radiator mounts good condition –
Front sway poly bushings, -
Front stock sway bushings –
8.5mm Jacob’s electronics energy core spark plug wires
Gtx 1 wire oxygen sensor
HVAC controls –
2 new in bag hydraulic lash adjusters
Fuel level sensor – free (go with gas tank?)
Turbo oil feed line –
Stock fuel rail with good fuel pressure regulator –
Passenger side window motor
Power window switch passenger side
Steering column plastic pieces
80W 4in Sony Xplode speakers, 25W RMS, 4ohm impedance
MAF from 626 GT
MAF from non turbo 323
7/8ths master cylinder with fluid reservoir
Corner light driver’s and passengers side
Gtx stock stereo
Passenger side tail light
Gtx hub, pre trimmed for vr4 big break front
Starter
2 alternators
Passenger side mirror with chunk taken out of edge
Drivers side under seat heating vent
E spec headlight with corner light (corner has broken glass)
2 or 3 heads
1 block
The parts car is currently sitting just outside of Roanoke, VA at the in-laws. The car includes:
Full interior (minus headliner)
a second set of rear interior seats
Full dash minus center console pieces
sensors
Falken Zeik 512 tires with 1,000 miles on them
stock wheels
stock struts - needs rebuild
full sealed power steering rack
all glass and body panels
all brakes
all 4 good hubs
rear axles
rear diff
sways and end links
**parts car does not have the following: passenger side door and fender, spoilers, a/c system, drivers side mirror, front bumper assembly, sunroof assembly and crank
Car is dirty from sitting under a car cover, but there is no rust and is water tight. We have title in hand. Taking offers.
List of sold and pending parts
Sunroof assembly and crank - SOLD
Upper and Lower spoiler - SOLD
Center console around shifter - SOLD
Diff lock motor (needs testing) - SOLD
K&N stock replacement filter - SOLD
Light bar , 2 super sport lights and 2 blazer 120 lights - SOLD
HKS intercooler 10x10x3 core – SOLD
original Rod Millen Springs - SOLD
Roadrace Engineering full set of solid strut tower braces - SOLD
Spare transmissionSOLD
3 or 4 Good Radiators - SOLD
3 heads 1 SOLD ... 3 still available
Good HKS muffler from the original system designed for the GTX SOLD
AFM cone adapter with an Injen Cone filter (cotton like K&N) - SOLD/Collins
Shifter Cables SOLD
oil pump SOLD
good fuel tank with pumps pending
Road Race remapped ECU SOLD
stock flywheels SOLD
gauge clusters SOLD
626gt Intercooler - SOLD
Road Race Manuel Boost controller SOLD
Dirtra Struts SOLD
Mazdaspeed Comp strut mounts. SOLD
Mazdaspeed top motor mounts SOLD
drive shaft SOLD
Front bumper SOLD
Whole wire harness SOLD
axles SOLD
Front strut brace – $80 SOLD
Rear strut brace - $80 SOLD
Rear Dirtra strut assemblies w/Rod Millen springs and Mazdaspeed comp top mounts - $325 SOLD
Front Bilstein insert assemblies w/Rod Millen springs and Mazdaspeed comp top mounts- $325 SOLD
AFM cone adapter with Injen filter - $30 SOLD
RRE manual boost controller SOLD
3 broken tab center wheel caps SOLD
2 4pt harnesses, unknown brand, 2in webbing SOLD
Engine wire harness including fuse box SOLD
Valve cover SOLD
Sunroof assembly and crank SOLD
drivers side mirror SOLD
rear seat belts SOLD
passenger side complete door SOLD
passenger side front fender SOLD
Front bumper turn signals (2), connectors taken off, wires still there SOLD
Front speaker grill covers SOLD
Grab bag of rusty motor mounts SOLD
front headlights and corner lights SOLD
shifter cables SOLD
full AC system SOLD
a large rubbermaid container full of miscellaneous parts like cam gears, braces, calipers, etc SOLD
subygirl is offline   Reply With Quote
Old 06-20-2010, 09:38 PM   #2
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 06-26-2010, 02:01 PM   #3
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 08-22-2010, 04:33 PM   #4
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 08-29-2010, 09:36 PM   #5
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 09-06-2010, 09:03 PM   #6
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 09-11-2010, 07:37 PM   #7
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 11-16-2010, 05:36 PM   #8
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 11-25-2010, 09:31 PM   #9
iceman.kcmo
Member#: 264683
you have a pm
iceman.kcmo is offline   Reply With Quote
Old 12-11-2010, 06:56 PM   #10
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump - updated parts list
Old 12-16-2010, 09:38 PM   #11
ngarcia
Member#: 267375
Originally Posted by subygirl View Post
This is an updated list!
Our GTX sold last year, but we still have the parts car sitting around. Car was hit in the rear, but there is minimal damage except for the wrinkle in the frame at the doors. Whole car is complete but without an engine/tranny. We do have several engine components sitting around that could be put together to make a complete engine set up though.
Gas tank - $100
Head with cams and valve cover - $150
Miata automatic pistons (gives gtx higher compression) & 3 gtx pistons –
Stock turbo (rebuild needed) with cracked manifold –
Engine wire harness including fuse box (missing battery ground wire and battery clamp) –
starter –
Stock BPV
HVAC controls –
Complete engine harness w/ fuse box, modified w/ new power and ground wire; 1 wire replaced, missing connector for the starter (1 wire ring terminal) –
Knock sensors (2), unknown condition –
MAF from 626 GT
Gtx stock stereo
Starter
2 alternators
Driver’s side mirror, end scratched
a second full set of interior seats
Full dash
sensors
stock wheels
shifter cables
steering rack
2 or 3 heads
1 block
full AC system
all brakes
all 4 good hubs
rear axles
rear diff
Car is dirty from sitting under a car cover, but there is no rust and is water tight. We have title in hand. $1,000 for everything
Shifter Cables SOLD
oil pump SOLD
gauge clusters SOLD
Dirtra Struts SOLD
drive shaft SOLD
Front bumper SOLD
axles SOLD
hi i was wondering how much you would charge for the doors and the passenger fender for if still available please e-mail me at [email protected]
ngarcia is offline   Reply With Quote
Old 12-27-2010, 10:40 AM   #12
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump!
Old 02-16-2011, 12:22 PM   #13
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
bump ... Joe is in VA pulling some of the more requested parts. If you have requested something, be on the lookout for a pm or email in the next day or so. Some stuff we can't pull just yet - anything that makes the car steer. We need to be able to move it still.
Old 02-21-2011, 09:59 AM   #14
ROBSGTX
Member#: 267814
Smile Mazda GTX parts
Still have the steering Rack left, I'll offer $50.00 for it plus shipping.
ROBSGTX is offline   Reply With Quote
Old 02-21-2011, 05:00 PM   #15
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Right now we need the steering rack to stay on the car so it can steer when we are able to find someone to tow it here. I'll definitely let you know if we find someone to tow it that we can afford!
Old 03-05-2011, 02:18 PM   #16
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
Bump.
We have the following parts added to our garage and now up for sale:
A/C compressor - $60
A/C condenser - $60
A/C lines (set, includes Receiver Dryer) - $65
All a/c listed above - $150
Control arms - $40 each
Front Hub $20
Knuckle (bare, no hub) $60
Knuckle Assembly- $70 each
Top rear spoiler - $60
Bottom rear spoiler - $60
Cam shafts, best set - $130
Cam shafts, second set - $100
Old 03-15-2011, 03:05 PM   #17
Ajtorres14
Member#: 276890
Do you still have tHe spoilers (rust free)??? Please let me know asap
Ajtorres14 is offline   Reply With Quote
Old 03-16-2011, 09:42 AM   #18
ROBSGTX
Member#: 267814
Default GTX parts..
Hey, how about just tie off the lower steering arms with a coat hangers on each side to keep the wheels straight when you tow it. I'll up the offer to $100.00 plus shipping.
I wold like to have part befor end of April if possible that's when my son returns from the Service.
Old 03-16-2011, 10:34 PM   #19
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
The spoilers have minimal rust to them - I consider them to be in good shape. One bolt hole on the lower spoiler needs to have a washer glued onto the bottom to help secure it since the thin piece of metal in the hole isnt' there anymore. Pictures are below. The last picture is after they were cleaned with 303 Aerospace Protectant so you can see what condition they were in and how they look cleaned up.
I hate to be a stickler about it but we need to be able to turn the car. Where it is parked, we will have to tie a tow rope to it and pull it to the street with my Father-in-law's Jeep and we will need to navigate some turns. We wouldn't be able to get to VA to pull it by April either. My husband came home from Iraq a year ago - I bet you can't wait for that homecoming!
Old 03-17-2011, 10:02 AM   #20
ROBSGTX
Member#: 267814
Default GTX Parts..
ThanK you for getting back to me about the steering Rack, also by any chance would you have the turn signal switch on left side of the steering wheel and the right side delay winshild wipper switch with handels also any relays under the dash board ontop of the fuse box, there is a gray relay I also need and any others, if so if you can send me some Pic's I'll be more than glad to buy them with the rest of the stuff..
And yes we can't wait to see him again..
Old 03-17-2011, 10:42 AM   #21
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
We have the steering column switch/handles here. Pics are below. $30 + shipping. We don't have any of the relays here with us in Indiana, but I can put them on our list of things to get off the car next time we are in VA.
Old 03-17-2011, 01:59 PM   #22
ROBSGTX
Member#: 267814
Default GTX Parts..
Great.. no problem let me know total w/ ship and how to do this.. or send me email with info..
Old 03-17-2011, 02:58 PM   #23
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
I don't know if I have it buried somewhere - I can't find it.... What is your zip code again?
Old 03-17-2011, 03:51 PM   #24
ROBSGTX
Member#: 267814
Default GTX Parts..
07307
Old 03-18-2011, 01:36 AM   #25
Ajtorres14
Member#: 276890
Can you check how much for the shipping to 00926. Thanks in advance and also thanks for the quick reply.
1988 Mazda 323 GTX complete part out subygirl MWSOC Private Classifieds 59 12-31-2015 02:20 PM
1988 Mazda 323 GTX complete part out subygirl Non-Subaru Stuff 7 06-08-2010 12:35 PM
1988 Mazda 323 GTX forsale! *RARE* gr8wheels South West Impreza Club Forum -- SWIC 13 03-11-2004 02:18 PM
FS: 1988 Mazda 323 GTX in AZ AaronB Private Vehicle 'For Sale' Classifieds 7 03-09-2004 04:29 AM
