Old 06-17-2010, 11:31 AM   #1
Local_Skater
Member#: 117454
2005 FXT PDX Stg II
2015 Kia Optima SXL
Default Early symptoms of HG Failure?
My Forester is a 99 with the SOHC EJ25. This is not the original motor. The new motor has about 70,000 miles on it and was installed professionally. Yesterday as I was driving the cabin began to fill with a white haze. I pulled the heater motor to see if leaves were caught in there, but there was no evidence of burning. Later, I noticed white smoke pouring from around the manifold and it seemed there may be a very slight bit of water getting into the oil and the coolant is slightly discolored. My initial impression is obviously head gaskets, but the other symptoms are not there. The car is not overheating and there is no sign of bubbling or overflow of coolant.
Am I in the early stage of head gasket failure and if so have I caught it early enough to avoid head work or any other major problems? Could this be something else?
Local_Skater is offline   Reply With Quote
Old 06-17-2010, 01:22 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Sounds like a HG to me.
PhilSine is offline   Reply With Quote
Old 06-20-2010, 12:26 PM   #3
BangR
Member#: 167558
1998 Forester
black
It's strange that your cabin filled with smoke...
BangR is offline   Reply With Quote
Tell Tale Signs Of HG Replacement? Bullwinkle Service & Maintenance 3 06-25-2009 01:37 AM
Symptoms of low tranny fluid (4EAT) Geek Guy Transmission (AT/MT) & Driveline 6 11-05-2001 12:03 PM
what are symptoms of a busted valve, and how much to fix? IMPREZAmike Normally Aspirated Powertrain 13 07-12-2001 01:23 PM
what are the symptoms of a bad clutch? Keith Technical Forum Archive 6 09-18-2000 11:12 PM
Message to Shiv.....what are symptoms of a blown MAF? ARG General Forum Archive 7 07-10-2000 01:35 AM
