Old 06-17-2010, 08:27 PM   #1
kmurphy
Member#: 163257
2006 sti
obp
Default Full stainless surgetank E85 ready.
Everything on this tank is stainless. Since nobody makes off the shelf AN bungs I had my machinist make me some in stainless. All bungs welded from the inside and mounted flush for a nice clean install. No worries about e85 eating away at the aluminum. Top 3 bungs are -6 while the feed is -8.
kmurphy is offline   Reply With Quote
Old 06-17-2010, 09:45 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
beautiful piece
eg33GC is offline   Reply With Quote
Old 06-18-2010, 11:50 AM   #3
Bob the fabricator
Member#: 104246
Nice job. Nice to see a proper tall cylindrical 'swirl pot' design that actually swirls the fuel and de-aerates it. I've never understood using a short, rectangular box as a surge tank.
Bob the fabricator is offline   Reply With Quote
Old 06-18-2010, 09:52 PM   #4
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Looks Great Man!!
YZ86 is offline   Reply With Quote
Old 06-19-2010, 01:24 AM   #5
piddster
Member#: 144285
1993 UHEV Legacy
I don't see how the fuel is going to swirl given the ports are perpendicular to the tangent of the cylinder. Also, how does spinning fuel help air rise to the top of the tank? The rising speed of a bubble is proportional to its size and the viscosity of the liquid. I don't understand how centripetal acceleration on air in a fluid is going to help it rise faster, unless your surge tank is an inverted cone.
Port placement should have a decent effect on keeping air and warm fuel away from the feed, even if it is a rectangular box. Considering the actual flow rate of fuel and its viscosity, air should have plenty of time to stay away from the outlet given proper port placement.
piddster is offline   Reply With Quote
Old 06-20-2010, 04:20 PM   #6
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Cant wait for this bad boy to come in the mail! Thanks Kelly
Wintershredder is offline   Reply With Quote
Old 06-21-2010, 12:21 PM   #7
Bob the fabricator
Member#: 104246
You are correct, I thought at first the ports were introduced at an angle, but looking at the pics again I see that they are in fact perpendicular.
Regarding the ability to de-aerate: Typically I install a baffle inside to help this out, but I've also seen that when the inlets are installed at an angle to induce a swirl within the container, and the outlet at the bottom is also welded in at an angle (however 90 off from the inlets), the heaver fuel stays at the perimeter of the tank, allowing ONLY fuel to be drawn into the secondary pump. The air will stay at the center of the tank, and eventually rise to the top.
Bob
Old 06-21-2010, 02:13 PM   #8
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Vibrant makes off-the-shelf SS bungs.
CKxx is offline   Reply With Quote
Old 06-21-2010, 02:33 PM   #9
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
kelly can you give me a call or some kind of update, im ****ing tired of this bull****
Bariga is offline   Reply With Quote
Old 06-21-2010, 04:12 PM   #10
piddster
Member#: 144285
1993 UHEV Legacy
Bob
Makes sense now. I'll keep it in mind for the next tank I make.
Old 06-22-2010, 01:51 PM   #11
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Real sweet looking setup.
nosmo is offline   Reply With Quote
GMC Envoy E85 ready? earshot Off-Topic 0 08-16-2006 03:42 PM
ESPELIR JGT 500 exhaust Full Stainless Steel jc0019 Private 'For Sale' Classifieds 8 02-27-2004 01:38 AM
SO CAL: Invida Full Stainless Steel Exhaust System legendr34 Private 'For Sale' Classifieds 7 02-03-2004 03:09 PM
JIC Bullet Down Pipe - full stainless! DigitalRacer.com Vendor 'For Sale' Classifieds 4 09-20-2003 11:20 PM
