Old 06-17-2010, 11:33 PM   #1
piddster
Member#: 144285
1993 UHEV Legacy
Default Surge tank made from scrap....
I spent some quality time at Nathan's welding the fuel surge tank together. Nice day for it too, lol. At least I can TIG weld in a T-shirt.
It's all made from 3/16" (.1875) 6061.
Welding was done with a Syncrowave 250. Balance was set at "8" and the gas was what Nathan decided to leave it at. Granted, I have about 20 hrs of aluminum experience.
The tank went together well. Little contamination, and thick material is very forgiving. What baffles me is there are no pin-holes or any leaks whatsoever. I pressure tested the tank at 40 psi in the bucket of water, and there were zero bubbles after five minutes.
I'm waiting on the mounting feet since I should probably see how it will play out in the car before I commit to the mounting scheme. Now I need to figure out the fitting and line situation, but my trunk is full of parts....
piddster is offline   Reply With Quote
Old 06-17-2010, 11:43 PM   #2
piddster
Member#: 144285
1993 UHEV Legacy
Rod was 4043. I hope to be able to anodize the tank. If I can't, I'll make a new one out of SS. E10 might be fine, but E85 might pose an issue, even if I don't don't have the fuel system to wrangle that corn crap.
Old 06-18-2010, 12:06 AM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
pulse?
eg33GC is offline   Reply With Quote
Old 06-18-2010, 12:35 AM   #4
piddster
Member#: 144285
1993 UHEV Legacy
Nope. Straight-up. I set the max at 170 amps, and flirted with the limit most of the time.
I used some heavy rod though. 1/8" IIRC.
Old 06-18-2010, 08:43 PM   #5
kmurphy
Member#: 163257
2006 sti
obp
4043 doesnt do well with anodizing. For anodizing you want to use the 5 series rod.
kmurphy is offline   Reply With Quote
Old 06-19-2010, 01:06 AM   #6
piddster
Member#: 144285
1993 UHEV Legacy
Dammit. My information was backwards. Oh well.
I can't run E85 until I do a major fuel system revision to the tune of about $1500, so I can just make a new one out of stainless when I get there. That's hot-rodden baby.
Old 06-25-2010, 11:04 PM   #7
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Looks good man.
sackytar is offline   Reply With Quote
Old 07-04-2010, 11:03 AM   #8
madmax718
Member#: 172501
Wow, for 20 hrs of alum experience, thats damn good.
madmax718 is offline   Reply With Quote
Surge Tank from MSI: Serious Business Turn in Concepts Built Motor Discussion 48 03-25-2010 10:19 AM
Surge Tank for use with Spec-C Tank based meth ket? dexterous Water/Methanol Injection, Nitrous & Intercooler Cooling 1 06-25-2009 11:30 PM
Hilarious, home made F1 car from scrap metal (PICS) JDM addict Off-Topic 44 07-02-2007 11:50 AM
made this fire extinguisher bracket from scrap metal frdawg Interior & Exterior Modification 47 06-21-2007 02:51 PM
Surge Tank/Surging Help!! HEKTIC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-15-2007 01:17 AM
