Old 06-18-2010, 04:18 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ: 2005 STI, EQ Built Block, VF39, E85 - 341whp/420ft-lbs!
Event: Custom Tune/Road Dyno
Ambient Temp: 80 degrees Fahrenheit
Elevation: 200ft above sea level
Weather: Sunny
Car: 2005 Subaru STi
Tuner: ED @ EQ Tuning
Peak HP at RPM: 341whp
Peak Torque at RPM: 420ft-lbs
Target Boost: 23psi peak
Fuel: E85
Engine/Power Modifications:
- EQ Tuning Stage 1 Shortblock (CP Pistons, ACL Bearings, Forged STI Rods, Balanced/Polished Forged STI Crank, Balanced & Blueprinted to our strict specs)
- EQ Tuning Stage 2 Heads (5 Angle Valve-Job, Bowl Blend, Stock Cams)
- Invidia Catless DP
- Greddy 3" Catback
- GT Spec UEL Headers
- Hallman MBC
- Walbro Fuel Pump
- K&N Typhoon Intake
- PE 850cc Injectors
- RPS Max Series Street Clutch
- Stock VF39, Stock Inlet, stock TGV's etc
- EQ Tuning Custom Tune using Cobb AP V2
This is a car we built about a year ago. The customer wanted more power, so we put in some 850cc injectors and tuned it on E85. The results were great all around. We didn't have to push the tune too hard to get great power and a very nice, smooth powerband. These E85 VF cars are just soo much fun .
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 06-18-2010, 04:25 PM   #2
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Very nice Ed!
Another stock turbo monster FTW!
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 06-18-2010, 04:30 PM   #3
anxiouz
Member#: 235268
2010 Cadillac CTS-V
Very nice. E85 is so great.
anxiouz is offline   Reply With Quote
Old 06-18-2010, 04:31 PM   #4
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
Headwork & built short block still w the stock turbo, I'm sure that's not gonna stay on long.
How is the idle on the cars you guys tune w pe 850's? I'm wondering if its jus certain tuners that have trouble tuning w those
Id switch to dw's if I had another chance
KB'izzle is offline   Reply With Quote
Old 06-18-2010, 04:39 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I usually get a clean, smooth idle with the PE's. This particular car idles smoother than stock. The only time I have trouble idling on the PE's is with turbulant intake setups. The Perrin blow-through MAF pipe, for instance is very tough to get a good idle out of especially when combined with PE injectors.
-- Ed
Old 06-18-2010, 05:59 PM   #6
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
there is something wrong with this car , it doesn't hold power all the way to redline
Godd job Ed
Old 06-18-2010, 06:29 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Godd job Ed
.. must be the software!
Seriously though, I think the stock inlet and TGV's are holding it back a bit up top. The cars with a full inlet/intake and TGV deletes usually hold power just fine to redline.
-- Ed
Old 06-18-2010, 06:47 PM   #8
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
-- Ed
So wait he built the motor and decide not to do TGV's while the intake manifold was off
renosubby is offline   Reply With Quote
Old 06-18-2010, 07:21 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep.. wasn't planning on anything big at all. Plans change
-- Ed
Old 06-18-2010, 07:37 PM   #10
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
-- Ed
I agree....
Old 11-30-2010, 12:05 PM   #11
Sil80sx
Member#: 231403
05 STi
This is exactly what I want!!.....
But it sucks because I even made a thread about little **** I should do when the motor is out and no one mentioned TGV delete
Sil80sx is offline   Reply With Quote
Old 11-30-2010, 05:56 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^^ u dont have to have the motor out to do tgv deletes.....
Old 11-30-2010, 06:02 PM   #13
Sil80sx
Member#: 231403
05 STi
Yeah I know it just would've been more convenient you know?
Btw what duty cycle are those 850s running at?
Old 11-30-2010, 06:47 PM   #14
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
around 95%
-- Ed
Old 12-02-2010, 07:17 PM   #15
importfanatic17
Member#: 145435
2005 STi
Nice work Ed.
Glad to see more people believing big power out of stock turbos these days
importfanatic17 is offline   Reply With Quote
Old 12-14-2010, 04:53 PM   #16
Sil80sx
Member#: 231403
05 STi
Im very tempted to drive up to you Ed! This is exactly what I want. Also how is it that the graph is so smooth even though the car still has tgvs?? Also what did the boost taper down to?
Old 12-14-2010, 05:23 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
im guessing 13.5psi
Old 12-15-2010, 03:30 PM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
im guessing 13.5psi
About 14psi.
-- Ed
Old 12-15-2010, 04:08 PM   #19
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
-- Ed
Do you consider the APS as a turbulent intake?
wil06STI is offline   Reply With Quote
Old 12-15-2010, 04:12 PM   #20
Sil80sx
Member#: 231403
05 STi
I have an old verison injen CAI, what do you think of that? And really 14 psi? How is it possible that it makes so much hp off very little psi? I think physics owns me on this one..... and I feel dumb because I know obviously it has to do something with the E85.....
Old 12-15-2010, 04:35 PM   #21
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
14psi is what it tapers down to at redline. It peaks at 23psi.
mapleleaf is offline   Reply With Quote
Old 12-15-2010, 04:51 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
yes its the e85. without the e85 the car would make ~300whp.
a stage2 sti vf turbo is already maxed past 5000rpm......all the extra power comes from the 3-5hp from every little piece.....then the most important ingredient is octane.
Old 12-15-2010, 05:23 PM   #23
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Its not the smoothest, but not the worst either.
-- Ed
Old 12-15-2010, 06:50 PM   #24
Sil80sx
Member#: 231403
05 STi
I understand that part, my question referred to the car maxing 320whp at 14psi @ redline. My tune tapers down to like 15psi I think and it only makes 260whp by then....
Yeah I figured since I was comparing it to mine =)
-- Ed
What would you consider the best intake for an vf E85 setup which will eventually be going to a future FP red setup?
Old 12-15-2010, 06:59 PM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
The APS CAI isn't bad. Since you'll be going with an FP Red, I'd recommend the 70mm.
-- Ed
EQ: 05 STI, VF39, E85 - 352whp/434ft-lbs @ 21psi! UPDATE: 119.7mph Trap! Equilibrium Tuning Proven Power Bragging 180 10-15-2010 02:43 PM
EQ: 2008 STI - Stock to Stage 2 - 65whp and 71ft-lbs increase! Equilibrium Tuning Proven Power Bragging 4 06-14-2010 08:40 PM
Feeler: (fl) 2005 STi with built block Jcrite8987 Private Vehicle 'For Sale' Classifieds 37 03-23-2010 03:02 AM
EQ Built Block, ATP 35R, 5,000ft Above Sea Level, 91 Octane + Meth = 437WHP! Equilibrium Tuning Proven Power Bragging 34 05-14-2009 08:14 PM
MA:400WHP Silver 04 STI, New built block w/ 5k miles. 25k Total miles ~$27,000 04RCSTI Private Vehicle 'For Sale' Classifieds 13 09-16-2006 02:29 PM
