Old 06-18-2010, 03:24 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ: 2005 STI, VF39, 91 Octane - 290whp/325ft-lbs!
Event: Custom Tune/Road Dyno
Ambient Temp: 88 degrees Fahrenheit
Elevation: 200ft above
Weather: Sunny
Car: 2005 Subaru STi
Tuner: ED @ EQ Tuning
Peak HP at RPM: 290whp
Peak Torque at RPM: 325ft-lbs
Target Boost: 18.5psi peak
Fuel: California 91 Octane
Engine/Power Modifications:
- Invidia Catless DP
- Greddy Evo 2 CB
- MadDad UEL Header/UP
- Hallman MBC
- Walbro Fuel Pump
- RPS Max Series Street Clutch
- Stock VF39, Stock Inlet, Stock Intake Box, etc
- EQ Tuning Custom Tune
This is another customer that I tuned over a year ago. The engine has 75k miles on it and it was time for a clutch. We did compression/leakdown test before doing anything else, and the results were absolutely perfect. The customer then decided to add in a header/UP combo and re-tune for the new mods. The results were awesome. 290whp on 91 Octane on a stock intake box is really impressive. The car ran very smoothly and is nice and quiet all around. This is a great mild setup!
*** Standard Dyno Chart Disclaimer ***
This software reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock WRX - 155-165whp
Stock STI - 215-225whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
380-390whp - 120-121mph traps
*** End Disclaimer ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
2005 WRX, Blouch 16G, 91 Octane = 290whp/270ft-lbs Equilibrium Tuning Proven Power Bragging 11 01-09-2013 07:13 AM
EQ: 2005 STI, EQ Built Block, VF39, E85 - 341whp/420ft-lbs! Equilibrium Tuning Proven Power Bragging 50 12-18-2010 11:20 PM
EQ: 05 STI, VF39, E85 - 352whp/434ft-lbs @ 21psi! UPDATE: 119.7mph Trap! Equilibrium Tuning Proven Power Bragging 180 10-15-2010 01:43 PM
EQ Stage 1 Shortblock, EQ Stage 2 Heads, VF39 + 91 Octane = 279whp/333ft-lbs! Equilibrium Tuning Proven Power Bragging 16 01-15-2010 08:02 PM
MZM/EcuTek 2005 STI VF39 91+meth benw Proven Power Bragging 10 06-30-2007 02:33 AM
