Old 06-18-2010, 09:43 PM   #1
jonney_boy
Member#: 28747
06 WRX
Default car slow to start in the morning.
I've noticed lately that the car is slow to start in the morning. It is always the first start of the day. Last winter when I had this problem I though it was the battery so I had that replaced. Lately i've noticed it starting again.
By slow to start I mean that instead of starting on the first or second crank, you will hear the engine turn over 2-3 times before it fires.
Is there any maintence items I could prob look into regarding this?
Car is a '06 wrx, fully stock with a cobb stage 1 tune. 5 speed. 70,000km on odo.
not much has been done in terms of maintience. Oil changes every 5000km and all fluids where changed out last year.
jonney_boy is offline   Reply With Quote
Old 06-18-2010, 10:05 PM   #2
kh15
Member#: 132400
how cold is it outside in the mornings when this happens?
what weight oil are you using?
kh15 is offline   Reply With Quote
Old 06-18-2010, 10:09 PM   #3
tranceport1
Member#: 92715
gdb aw sti
z32tt, s13 silvia
Default slow start
try the fuel filter if you haven't changed already.
Next would be ignition items and o2 sensors.
Clean your intake filter (or replace) and MAF
tranceport1 is offline   Reply With Quote
Old 06-19-2010, 04:15 AM   #4
jonney_boy
Member#: 28747
06 WRX
not cold at all, it was about 10 deg C outside today........ I didn't even have a jacket on.
I'm running standard castrol gtx 5w-30.. so I don't "think" it is that. It is really noticable when it drops to -10 or 15 tho. Funny thing is second start of the day and it is completely normal... even if it's after work (sitting for 8+ hours).
Tranceport - I was under the impression that the '06 does not have a fuel filter, it is just an in tank sock that is "auto clean"..... ignition items.. I guess I could do plugs soon, even tho they arn't due yet.
Intake filter, i'll defently check that, replaced it 2 years ago and checked it 3-4 months ago, looked fairly clean to me. I do have a spair on hand if need be
MAF, any way to clean this?
Old 06-19-2010, 04:26 AM   #5
DIRTWRX
Member#: 186402
2002 I eat gravel
for breakfast
there should be an external fuel filter, on the right side of the intercooler, look's like a black can with two tube;s going into it. I have an 02 wrx so it may be different but not sure.
DIRTWRX is offline   Reply With Quote
Old 06-19-2010, 04:28 AM   #6
jonney_boy
Member#: 28747
06 WRX
DirtyWRX, I know what you are talking about as I also have a '03 ts at home, and that filter is "missing" on my wrx. I"ll double check in the morning but i'm fairly sure it's not there.
What time is to0 early in the morning to work on the house? [email protected] Off-Topic 24 06-19-2010 08:22 AM
PROBLEM!! crank case sensor, wont start in the morning sike43 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-09-2010 07:32 PM
Is my car going to start on Friday morning? Mike Wevrick Off-Topic 11 01-23-2007 09:26 AM
My car probably won't start in the morning due to cold. What should I do? bruticus Service & Maintenance 22 01-15-2004 12:15 PM
My car probably won't start in the morning due to cold. Any suggestions? bruticus Tri-State Area Forum 8 01-14-2004 01:08 PM
