Old 06-20-2010, 12:22 PM   #1
wr-ecks
Member#: 148183
05 WRX STI
Default Help diagnose problem please.
We picked up a 90 Legacy L 2.2l last night for a super good deal but only because it has an issue the PO couldn't solve.
The car shuts off randomly, it could take 30 min or it could shut off every few seconds. It doesnt buck or throw any codes or give any warning at all. It very much feels like an electrical problem as opposed to a fuel problem. Every single time it fires right back up with no hesitation or waiting.
Its been to a couple shops but all it sounded like was done was some minor stuff like looking for loose grounds and making sure no wires were chewed through. The PO didn't want to pay a shop to guess at it and throw parts at it so he sold it to us. Any ideas?
Im thinking maybe the ECU???
wr-ecks is offline   Reply With Quote
Old 06-20-2010, 01:03 PM   #2
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
The shutting off thing sounds exactly what happened to me when my MAF went out. I don't know if the 90's car uses a MAF, but if it does happen to, that could be something to look at.
And when I say it sounds exactly what happened to me, i mean, identical.
Frogsthatmoo is offline   Reply With Quote
Old 06-22-2010, 11:23 AM   #3
Murphy's Law
Member#: 243936
2011 Impreza WRX STi
Dark Blue
is it down on power and/or is it hard to start? does the engine just stop or a misfire and die?
Murphy's Law is offline   Reply With Quote
Old 06-22-2010, 12:00 PM   #4
Tessai
Member#: 214184
1999 Legacy Outback
As for the issue, I know OP said that they had checked for loose grounds... how about extra grounds? I had another car like this where someone had ghetto-rigged a negative battery terminal cable in an attempt to relocate the battery, but a botched stereo install could do the same thing. See if you've got any extra wires tapped in to the battery terminal cable that is grounding where it shouldn't be.
In my case I had a wire that had enough slack to swing side to side. It ran under the car and would ground out against the trans and killed the car.
Just a thought.
Tessai is offline   Reply With Quote
Old 06-24-2010, 11:29 PM   #5
wr-ecks
Member#: 148183
05 WRX STI
Sorry about the long pause inbetween posts. finally upgraded to Windows 7, Vista sucks bad. Anyways...
Update: Works been nuts so I havent had much time to work on it but I swapped the ECU, I found one at the local pull a part for 10 bucks so I grabbed it. Somebody broke the MAF so have to wait on that, ECU didn't solve the problem so next on my list is the MAF. autoparts store wants 220 bucks for one so I think I'll wait until I can get one for cheap for the wrecking yard so I at least know my 220 bucks is going to fix it.
I'll look around for weird wiring stuff but I don't think that would be it. The PO just used it for a commuter and never isntalled any kind of aftermarket anything as far as I know. Still has the stock deck and all. It used to run fine and then suddenly stopped one day.
It never starts rough, always starts right up no problem at all. Dies almost instantly. It bogs for a second then dies.
Old 06-28-2010, 11:53 AM   #6
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Most likely it is the MAF, but also check that your crank and cam sensors are functioning properly. My crank sensor burnt out and needed replacement because my car would bog. Definitely check the MAF first, and most likely that will be the problem. If it still is not the problem, crank and cam sensors for the 1st gen legacys are very expensive because they come with the wire and all. You cannot just disconnect them at the sensor like with the 2nd gen models.
Jessekrs123 is offline   Reply With Quote
Old 07-02-2010, 10:45 PM   #7
wr-ecks
Member#: 148183
05 WRX STI
Hello again. It was the MAF. it run like a champ for a few days now. Thanks for your help, im sure it would have taken me a few more guesses before I got to the MAF so If I happen to run into any of you I owe you a beer. Thanks again!!
Old 07-02-2010, 11:24 PM   #8
Jessekrs123
Member#: 236927
1984 BRAT
^^^ Glad to hear your car is good to go now.
P0172- help diagnose problem pls! csutherland Normally Aspirated Powertrain 4 11-29-2006 03:36 PM
help diagnosing problems with 97 jetta please! jonnydajibba Off-Topic 30 07-12-2006 06:30 PM
need help diagnosing problem... Enigma76 Car Audio, Video & Security 4 05-24-2004 01:08 AM
Help diagnosing problem / mpg etc. dolinga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-14-2001 08:32 PM
Help diagnosing plugs please Tony Normally Aspirated Powertrain 3 07-31-2001 12:24 AM
