Welcome to the North American Subaru Impreza Owners Club Sunday December 21, 2014
Old 06-21-2010, 05:58 PM   #1
KGAWDTSi
Member#: 73368
2004 WRX wagon Stg.2
Default removing paint splatter
My wife ran over some paint with her car. I do not know what kind of paint it was but it is now splattered up on the quarter panels. What would be the best method to remove this paint without damaging the cars paint. It is on too thick for a clay bar to remove. I read if you put some vasoline on it that should loosen the the paint but that did not work even after power washing using hot water (approx 135 degrees). I also read that WD-40 may do the trick but that also did not do anything. I was told to try paint thinner on a rag and if that does not remove it to try laquer thinner on a rag but I am afraid it will damage the cars paint. Any tips as I am at a loss here on how to remove it. Also she did not tell me it was there so it has been on there for a few weeks making probably even harder to remove. Any advice? Thanks
KGAWDTSi is offline   Reply With Quote
Old 06-22-2010, 03:23 AM   #2
jxkim
Member#: 239150
2003 WRX Sedan
with any car detailing / cleaning... always start with less harsh (severe) methods. better to be safe.
i dont know why vasoline would remove paint???
try bug/tar remover or goo gone. it probably wont work but worth a try if you have some. gotta use lots of elbow grease. wd40 is a cheap substitute of this method.
i used to paint apartments as a summer job and a great trick i picked up was how to remove paint from the floors (usually hardwood). lime works wonders, so i used windex w lime. also i believe a vinegar/water solution should work similarly. the windex w lime cant be good for your paint but it wont do anything terrible. nothing you cant polish out
jxkim is offline   Reply With Quote
Old 06-23-2010, 08:26 AM   #3
KGAWDTSi
Member#: 73368
vasoline was suppose to soften up the paint so that it comes off easier but does not work. I did try some bug and tar remover but that did not work either. I was trying to use something less invasive as to not ruin the cars paint but nothing seems to be working
Old 06-23-2010, 09:38 AM   #4
ieiscooby
Member#: 38258
2004 EWG VF30 WRX
PPG makes an awsome product called Duraprep Prep 400. It is an overspray remover. We use it at our shop and its a commercial product, but if you go to a PPG distributor they can probably get it for you. It does come in a pint spray bottle. The stuff is amazing. It will not damage the surface, pending you follow the directions.
ieiscooby is offline   Reply With Quote
Old 06-23-2010, 05:14 PM   #5
KGAWDTSi
Member#: 73368
Thanks for the tip. I will see if I can find a distributor near me and give it a try
Removing paint splatter RedBean Interior & Exterior Modification 5 04-20-2004 02:11 PM
Paint Splatters on my car bobg Car Care & Detailing 7 06-11-2001 07:43 PM
Remove painted pinstripe? MichiganRS Interior & Exterior Modification 3 05-16-2001 12:20 PM
Removing paint off of CF hood stimpy Interior & Exterior Modification 20 01-10-2001 02:35 PM
Removing paint from 2000 RS rims. david2z4 Technical Forum Archive 0 07-31-2000 09:54 AM
