06-21-2010, 06:13 PM | #1 |
Member#: 178175
Vehicle:05 WRX R.I.P. 06 E85 STi Stg 2 MSPTUNED |
Feels Rough
I waxed my car this weekend. Two different coats.
First Meguiar's swirl X and then Meguiar's Tech 2.0 wax. After the car was waxed it felt like a glass table, smooth. Today I was at the gas station and ran a finger across my paint and if feel like fine sand paper. Is this the was wax is suppose to feel like after it sits for a couple of days? I'm not a pro at detailing and took the challenge on myself. Some information would be much appreciated.
06-21-2010, 06:17 PM | #2 |
Member#: 15934
Vehicle:2021 GTI Cornflower Blue |
You didn't clay your paint before you waxed it, so you essentially waxed onto of the deep down dirt.
Also, how long did you let the NXT cure on the paint? I always let it sit for at least 30 mins before I remove it. Was the car parked outside the entire time the entire time? These all can affect the longevity of waxes. |
06-21-2010, 06:23 PM | #3 |
Member#: 178175
No I did not clay before I waxed, but I did wash.
I let it cure as I applied onto the car. Started with the hood and worked my way towards the back. As I finished the back I came back up front to remove it. Did it this way for both the swirl X and the wax. When I waxed it, it was parked in the shade. I do on the other hand park outside as I do not own a garage. Only on the weekend the car is exposed to really bright sun light as I park in my parking garage at work. |
06-21-2010, 06:46 PM | #4 | |
Member#: 15934
What I usually do is apply the NXT, then I go around and clean up the wheels, dress the tires, wipe down the windows and polish up the exhaust tip and THEN remove the NXT. Also, parking it outside will make a huge difference. When it gets cooler at night and everything gets that fine layer of condensation on it, well that's what you're feeling on your paint. If you washed it, I'm betting that it will still feel smooth. Not to mention the fine layer of dust on your paint now from being outside in the elements. You can apply layers of NXT on your car as long as it's 24 hours apart. Maybe wash it again and apply a new layer of NXT, the way that I described above and see if that helps. |
06-21-2010, 08:09 PM | #5 |
Member#: 178175
NXT = Swirl X? or Wax?
I'm kinda confused. |
06-21-2010, 08:57 PM | #6 |
Member#: 150710
Vehicle:2012 SWP WRX Hatch 2005 Lotus Elise |
NXT = wax.
Look into meguiar's clay kit if you like the brand. It'll go a long way in making your paint feel even smoother. But since clay takes everything off your paint, you'll need to wax it again after. |
06-21-2010, 09:15 PM | #7 | |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
06-22-2010, 02:32 AM | #8 |
Member#: 239150
Vehicle:2003 WRX Sedan |
^ yes the only product you should let dry is the wax. all else you buff out while its still wet. work in small sections.
claying removes a lot of your wax layer (protection is then gone). and regarding the original post. nxt 2.0 is a pure wax. if youre lazy and dont wanna clay i suggest a cleaner wax. this has properties that remove impurities from the clear coat. if you wanna use a pure wax like nxt you should clay your car. you can get away with a few washes/waxing afterwards, but dont go too long without claying. (how often should you clay? depends on how much you drive and your area... but once or twice a year is fine for me) if you decide to go with the cleaner wax route... meguiars has been around forever Last edited by jxkim; 06-22-2010 at 02:37 AM. |
06-22-2010, 10:11 AM | #9 |
Member#: 178175
Thanks for all the imput guys. Much appreciated! I will redo the whole car this upcomming weekend if weather decided to cooperate here in Chicago. We keep having severe thunderstorms and its hard to get anything done when it come to waxing or detail a car. So caly bar then polish with small sections at a time, followed my wax should give it a really nice shine!
06-22-2010, 10:15 AM | #10 | |
Member#: 175608
W. Canada
Vehicle:2006 Impreza 1998 Honda VFR 800FI |
06-22-2010, 11:28 AM | #11 | |
Member#: 25187
The following is a collection of link I put together last year. There are several articles within that cover these topics in more detail and should help: Detailing Library Evaluation and product knowledge is key to choosing what will work for you. |
06-22-2010, 11:53 AM | #12 |
Member#: 178175
Nice thread. Subscribed just so I dont loose all that great information.
06-22-2010, 12:22 PM | #13 | |
Member#: 211432
BAIC
Vehicle:2012 WRX STI DGM |
Swirl X = Polish Tech Wax = Wax/Sealant Did you work in Swirl X or did you just apply it and remove it? Polishes need to be worked in so the abrasives can remove the defects in the clear. edit: Just read your last response. Now that you said you're redoing your car this weekend, I would suggest the following: Wash with Dawn (to remove all previous coats of wax and degrease surface) Claybar (to test if necessary, take a plastic bag and place your hand in it and wipe across the paint slowly using very light pressure, if you can feel bumps then it needs to be clayed). Wash again (if clayed) Wipe car down with 50/50 Isoprophyl Alcohol and water Polish (if you have swirl marks, if not just use a cleaner like suggested. Polishing removes small amounts of clear coat [micrometers at a time], and you should only do it 1-2 times per year) Wash Wax |
06-22-2010, 12:34 PM | #14 |
Member#: 178175
06-22-2010, 02:25 PM | #15 |
Member#: 239150
car washing solution has special properties to not strip your car of the "grease" aka your wax~. if you use dish washing solution like dawn, it is designed to remove all grease!
06-22-2010, 04:43 PM | #16 |
Member#: 74229
Vehicle:2004 PSM WRX |
30 minutes is a bit overkill for an OTC wax. Curing happens after the product has been removed. Also, I don't believe you can effectively layer NXT wax since it has cleaning additives in it. Applying additional layers will only ensure coverage.
06-22-2010, 05:36 PM | #17 |
Member#: 239150
i dont like exposing my car unprotected to hard hose water after claying. (re-washing) i think its sufficient giving a good wipe down using detailer and clean microfibers
06-22-2010, 09:28 PM | #18 |
Member#: 25187
06-22-2010, 09:30 PM | #19 |
Member#: 25187
06-24-2010, 01:39 PM | #20 |
Member#: 74229
I don't see why you would need to wash the vehicle again after claying before waxing if you used a quick detailer as lube, unless you used it excessively and there is a lot of left over residue. They do sell paint cleansers made to remove cleaning chemicals and prep the paint before waxing, but they're typically used after polishing.
06-24-2010, 06:53 PM | #21 |
Member#: 239150
the clay and lube leave behind that residue. but i just use microfibers and detailer to get it off.
06-24-2010, 10:41 PM | #22 |
Member#: 206316
SCIC
Vehicle:2009 STI StageII OBP |
This is an excellent thread. I have never used Dawn as a de-greaser when washing. Awesome!
06-25-2010, 12:33 PM | #23 | |
Member#: 25187
As long as you work cleanly, you can clay the whole car without having to re-wash it as Vew mentioned. Personally, I find re-washing a waste of time IMO/IME. After polishing is a different story. Sometimes I find it easier to re-wash using one of my APC's to remove the oils, residue and dust. ....it just depends. It's all a matter of preference though and if it works for the user, then that's all that matters in the end. |
06-25-2010, 12:47 PM | #24 |
Member#: 25187
....while I prefer other products, I've used Dawn a few times and found it to be a relatively effective product remover. Most dressings and waxes are pretty easily tackled by it although some sealants can require multiple washes before all traces are removed.
07-01-2010, 05:40 PM | #25 |
Member#: 15934
I was thinking about this thread last night. I washed and waxed my Mazdaspeed on Saturday night (6-26) and yesterday on my way past it in the garage, the paint still feels smooth and slick.
I applied NXT by hand and let it cure on the paint for 30-40 mins and wiped it off by hand as well (I usually do both with the DA buffer) but it was late, I didn't want to wake my 4 month old twins. So I think it's being out in the elements overnight with the condensation. My car sits in a garage overnight but has been parked in the sun outside @ work for 8-9 hrs a day since then. |
STi cold engine feels rough | volkl23 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 01-30-2007 03:52 PM |
Was washing my car last night and discovered that my roof has a rough feel | BobbyV | Car Care & Detailing | 9 | 03-23-2005 10:46 AM |
clutch feeling a bit rough | gtlegg | Transmission (AT/MT) & Driveline | 0 | 02-15-2005 06:45 PM |
New 2.5RS engine feels/sounds rough | Airboy | General Community | 6 | 10-18-2004 11:28 PM |
clutch feels sticky and rough | CRZYMAN118 | Service & Maintenance | 0 | 11-19-2003 12:32 AM |
