#1 |
Member#: 247820
NWIC
Vehicle:1992 Legacy Wagon |
I have a 1992 Legacy, and when I turn the car on (not ignition), I hear a strange buzzing type sound coming from inside the transmission pan. Drained fluid, took pan off and can't seem to find where it is coming from. Sounds like a relay going on and off. But as it buzzes, the green "power" light will flash the same pattern as the sound. And the AT fluid temp light will do the same thing. Any ideas?
#2 | |
Member#: 98425
Vehicle:97 Outback |
it is probably a solenoid, maybe a shift solenoid. (solenoids control the flow and fluid pressure to get the trans to do what the computer says.) there are several in the trans. the "valve body" inside the pan on the bottom of the trans holds a bunch of them. you can probably replace the bad one if you can identify it. if you have to pay for it to be done, it may be very expensive. it may be possible to replace the whole valve body from a good trans or depending on the repair cost, just swap in another trans. |
#3 |
Member#: 247820
NWIC
Thanks, I will keep looking into it.
I am going to try a few more things, such as check the ground for the transmission ECU. I also read somewhere to look at the ATF temp sensor, but I am having trouble Identifying that. |
#4 |
Member#: 247820
NWIC
ATF temp sensor is bad, I believe. If anyone has knowledge of what it looks like/how to replace, please share!
#5 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
I'd check what the TCU is telling you the problem is.
You can pull the codes from the TCU. The instructions are on my site. www.surrealmirage.com/subaru/trans.html Josh |
#6 |
Member#: 247820
NWIC
Love your site.
21, ATF temp sensor. What does that look like and how do I locate it. |
#7 |
Member#: 4800
TXIC
It's on the valve body. Going to shoot you a pm with more info.
Josh |
#8 |
Member#: 247820
NWIC
| Thread Tools | |
| Display Modes | |
| Strange buzzing sound on start-up | FarmerJoe | Electrical & Lighting | 3 | 03-05-2009 05:19 PM |
| Strange Buzzing sound @ 2750rpm....? | theleveler | Normally Aspirated Powertrain | 7 | 11-29-2007 05:45 PM |
| "power" light mod for alcohol injection | trevman2 | Alaskan Impreza Club Forum -- AKIC | 8 | 03-21-2005 11:52 PM |
| Flashing "POWER" light on dash in 1993 FWD Impreza | KUgrad | Transmission (AT/MT) & Driveline | 15 | 07-11-2003 11:08 AM |
| strange sort of buzzing sound!?! | scoobyboost | Factory 2.0L Turbo Powertrain | 4 | 12-27-2001 05:26 PM |
