Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-22-2010, 02:05 PM   #1
gonzoactive
Member#: 77976
Default 2.2 Temperature diary.
I have a stock 2.2 engine that I pulled from a 92 legacy wagon, and put into a 5000 lb VW vanagon camper. I installed a digital temp gauge to drive myself crazy.
The engine goes in the back and the radiator is in the front. I have the standard 170F subaru thermostat, and radiator fan switch operating at the low and high 190s.
In NC the temperature is 103F today and the temperatures on my cyberdyne digital gauge is reading "high." Driving in mostly stop and go traffic I range from 204F to 210F. A few times I have seen 225F. While moving, I see 196F at 45 mph and this drops to 192F at about 80 mph. The subaru parts person told me to pull over at 206F.
1) What temperatures are any of you getting in similar heat conditions?
2) At what temperature am I going to blow a gasket or ruin the engine?
3) I thought about changing the rad temp fan switch to activate at lower temps, but I would have to manually shut off AC if the car became too hot.
gonzoactive is offline   Reply With Quote
Old 06-22-2010, 02:21 PM   #2
suex
Member#: 243393
o6 impreza rs
E-fan with an on/off switch on the dash... Just leave it on in the city, turn it off on the hyway, way cheaper to replace than the whole motor...
suex is offline   Reply With Quote
Old 06-22-2010, 05:30 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I'm not sure what temp the head gaskets will start to blow at, nor do i think there is a set temp but if the dealer is saying 206* is bad then i would definitely look into solutions to bring it down. A quality and still cost effective solution to keeping the coolant a little cooler would be to add a lower temp thermostat. If it 160* thermostat can lower your temps another 10-15 degrees over the 170* then that definitely puts you back in the safe zone.
Mike
GrimmSpeed is offline   Reply With Quote
Old 06-23-2010, 02:22 AM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Try a product by Redline called "Water Wetter" it's pink fluid in a clear bottle. A lot of guys that race use it to keep the temperatures down in their race cars. You should be able to get it at any parts store.
PhilSine is offline   Reply With Quote
Old 06-23-2010, 05:22 PM   #5
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
+1 You should see a 10-15 degree decrease. Ive never used it with antifreeze, only water, so read the bottle carefully. But it definitely works!
snoopyone8 is offline   Reply With Quote
FS : Autometer Sport Comp 2 oil temperature gauge car_freak85 Interior/Dressup/Audio & Security 25 02-08-2016 01:57 PM
Run phase 1 dual port 2.2 heads on a phase 2 single port 2.2 block? wagonovsky Subaru Conversions 12 03-01-2006 11:27 AM
Why can't use 2.2 or 2.5 PH1 trans with 2.5 PH 2? rallynutdon Transmission (AT/MT) & Driveline 6 04-02-2003 07:01 PM
2.0, 2.2, 2.5 rbehny General Forum Archive 6 03-03-2001 01:50 AM
2.2 v.2.2 turbo trans iceman Technical Forum Archive 3 06-22-2000 08:32 PM
