Old 06-13-2002, 02:16 PM   #1
adamsrs
Member#: 3768
Unhappy EGT installed...but how do i sela the threads? They LEAK!
HYey guys, just a quick and easy question! What did you guys use to seal the threads of your EGT probes? Mine screwed in but it has a bit of leak thus giving a wavy and false reading! Thanks! Any info would be GREAT!
adamsrs
adamsrs is offline   Reply With Quote
Old 06-13-2002, 03:05 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Home Depot, teflon tape. $0.89. But, I don't know if it could withstand the heat.
Loctite?
wcbjr is offline   Reply With Quote
Old 06-13-2002, 03:12 PM   #3
8Complex
Member#: 922
04 FXT
Red
Hey, be more vague next time.
What kind of probe? What kind of fitting? What are you currently usingn to seal it? How much torque did you give the fittings?
Teflon tape will work, but a good anti-seize will work better. Just gotta torque it down pretty good and make sure it seals, though not strip the hell out of it. I don't know a real number, though, sorry.
Old 06-13-2002, 04:49 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I may be way off here, but unless the amount of leakage is *huge* I can't see the reading being that off- the leakage is around the probe after all. Is something wrong with the sender? I've had 3 go bad on me thus far (I'll install #4 one of these days ).
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 06-13-2002, 06:22 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Sorry for hijacking the thread, but how did you know the senders went bad?
Impreza Rider is offline   Reply With Quote
Old 06-13-2002, 06:45 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
To continue the hijacking, the needle on the gauge started fluctuating wildly, and eventually just stopped moving and pointed straight down (between 0 and 1600 deg F on the Autometer Phantom). The whole gauge was replaced and it still happened- replaced the sender (the probe) and it worked fine again. This has happened with one competition probe and two "regular" probes thus far. I have another competition probe to replace the presently broken probe with, I just have to get around to doing it. They have no idea why they keep blowing- it never sees temps over 1400-1450 deg F.
Brian
Old 06-13-2002, 07:53 PM   #7
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
I'm assuming you're using either a BSPT or NPT screw in bung. If you want a tighter seal, you screw the bung in more. If you've reached the end of the bung's threads, then you tapped the hole too far.
Austin is offline   Reply With Quote
Old 06-13-2002, 09:58 PM   #8
adamsrs
Member#: 3768
Sorry, Defi gauge and bung and sender and everything...it is 1/8" pipe thread i think.....and hmmmmmm, it is in there pretty tight...the needle DOES fluctuate a lot though...from like 1400-1500 and like 800-1000...seems weird.
Thanks Austin!
adamsrs
Old 06-13-2002, 11:06 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
The fluctuations could be your computer doing a timing dance and causing different EGT's
And if you are using pipe thread (NPT) and you have leaks, you did something wrong. I would get a crush washer (Like on certain spark plugs) and use that.
anyway, just a few thoughts
Eric
Eric SS is offline   Reply With Quote
Old 06-14-2002, 03:34 AM   #10
Ethan
Member#: 246
I'm not too sure about them Autometer Comp probes. Every once in a while my probe will just stop reading for a while. I have no clue what the problem is, though I never got around to sending it in for a replacment. BUt I seem to read a lot of people have problems with this probe
Ethan is offline   Reply With Quote
I shot a jack through the rocker panel, how do I seal it? Kyguy Interior & Exterior Modification 18 06-05-2006 12:49 AM
I want New rims but how do you do the math ?? BoostdBoxer Tire & Wheel 15 06-28-2004 10:42 AM
dumb question, but how do you remove the rear bumper on wrx? M32WRXin3seconds Newbies & FAQs 3 08-14-2003 03:37 AM
But ... how do you tell the time? WAFlowers Factory 2.0L Turbo Powertrain 27 09-13-2002 04:01 PM
But how do you install it redrex3 Factory 2.0L Turbo Powertrain 5 05-09-2002 04:54 PM
Message Board Statistics All times are GMT -4. The time now is 12:47 AM.
