Old 06-23-2010, 09:29 AM   #1
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Default Diagnose my problem please
2006 Impreza 2.5i
Nearing 60k miles
Car runs fine, but the engine started bucking this morning when I reached 4k to 4.5k RPMs during acceleration. It felt like hitting the rev limiter, but at lower RPMs.
The check engine light came on, and flashed for a few seconds. It went away when the RPMs got lower. The car is now parked and I will book an appointment with my dealership.
In the meantime, can anybody help me diagnose my problem?
Paraskass is offline   Reply With Quote
Old 06-23-2010, 10:28 AM   #2
dcleal
Member#: 178135
2006 Impreza 2.5i
A flashing check engine light indicates a severe misfire that will damage the cat. Your first step should be to go to auto zone and get them to pull the codes for free. Make sure you get the code so we can see it exactly. It is most likely fuel or spark related. What is the service history of the vehicle?
dcleal is offline   Reply With Quote
Old 06-23-2010, 11:16 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
Yep, flashing CEL is a misfire. I personally wouldn't call it 'severe' though.
Basically, you could start the car up now and everything will be fine. The CEL will still be on, but not flashing. Take it to autozone/advance and pull the code, write it down, and clear it from the ECU. Drive home and everything should be fine. It happened to my old '95 about once a year and was never a big problem.
I'd check your spark plugs and wires just to make sure everything is in good working order. I wouldn't freak out about it though... when it happens you feel like your car is going to explode, but you're really fine. Just pull off the road ASAP if it starts happening and turn it off.
Old 06-23-2010, 11:19 AM   #4
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
I've owned the car since day one.
It's been pretty much problem free. There were 2 times when I was late on oil changes, nothing major.
It's nearing warranty now and this happened.
The check engine light blinked a total of maybe 5-6 times before dissapearing. The car feels normal under 4k rpm.
Old 06-23-2010, 11:30 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Your ECU is in safe mode which is why it won't rev past 4500 RPMs. Like dcleal said; the flashing CEL is an indication of misfires. Definately get the cose read and report back. could have a bad knock sensor or something like that but you won't know until the code is read.
PhilSine is offline   Reply With Quote
Old 06-23-2010, 11:35 AM   #6
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
They have me booked for Friday morning...
Any danger driving the car home today (about a 3 mile drive, and I can take it slow)?
Old 06-23-2010, 04:41 PM   #7
dcleal
Member#: 178135
2006 Impreza 2.5i
If it is driving fine and the check engine light is not on than you can drive it. Apparently the problem is only during high RPM so just try to avoid that rpm range. Have you ever had the spark plugs changed or fuel filter replaced? The spark plugs are recommended every 30,000 miles and the fuel filter is recommended at 60,000 miles.
Old 06-23-2010, 11:47 PM   #8
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
and where is this fuel filter located???
The G.O.A.T. is offline   Reply With Quote
Old 06-23-2010, 11:54 PM   #9
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
fuel filter is not replaceable on the 06-07 2.5i. its directly on the pump in the tank.
kewlboxer2 is offline   Reply With Quote
Old 06-24-2010, 10:23 AM   #10
The G.O.A.T.
Member#: 149724
Blood red
That is what I thought, is it like the gm one where it is on the bottom and if you are 1/2 full or more the fuel is unfiltered???
Old 06-24-2010, 10:57 AM   #11
BKscooby
Member#: 163601
Pull the code, and we'll be able to help. Otherwise it just keeps me guessing that it is a bad coil or or a plug.
BKscooby is offline   Reply With Quote
Old 06-24-2010, 11:33 AM   #12
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Spark plugs never changed.
I will find out tomorrow morning.
Old 06-24-2010, 06:16 PM   #13
dcleal
Member#: 178135
2006 Impreza 2.5i
although the filter is on the fuel pump it is still recommended that it is replaced every 60,000 miles. The labor time is only .5 hour so it can't be that hard.
Please help diagnose my problem... mustang killer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 02-19-2008 09:04 PM
help diagnose my problem scoobydrew06 Brakes, Steering & Suspension 1 03-05-2005 09:59 PM
Diagnose my car please? trustWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-06-2004 09:19 PM
Diagnose my problem with my 2nd gear FraudulentNeon Transmission (AT/MT) & Driveline 6 05-11-2004 06:29 PM
