Old 06-23-2010, 11:53 PM   #1
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Default Uppipe Question for Exhaust Nuts/Engineers
I'm not sure if I'm completely off base or not, but I'd like to hear everyone's thoughts on this.
Here are some basic assumptions on my part so if any one of these is wrong I doubt this will work at all
1. A small diameter uppipe will decrease spool time significantly
2. The reason no one runs a small diameter uppipe is because it will limit total flow during full boost.
Could a system be designed relatively similar in nature to this, but for the uppipe?
Basically there would be the primary smaller pipe that would run around the main pipe so spool would be fast then the main uppipe would open during load.
Here's a Paint rendering LOl
Would this even be worth the trouble? How would the wastegate or valve to the bigger pipe be controlled? Could it be a purely mechanical design? What could be used to prevent backflow into the big pipe?
Spike700 is offline   Reply With Quote
Old 06-26-2010, 12:18 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
This would not be worth the trouble.
You would not gain much in spool or top end due to the large discontinuity in the flow path to the turbo. You are much better off going with a well designed set of headers and uppipe.
To make your idea really work well you'd need 2 flowpaths from the head to just before the turbo. You would also need a way of having the valve(s) sealed in the pipe which would be very difficult at the temperatures that exhaust runs at next to the head. Back at the muffler the exhaust is much cooler.
speedyHAM is offline   Reply With Quote
Old 07-11-2010, 03:25 AM   #3
azn2nr
Member#: 35276
spracing is way ahead of you. havent seen it in this particular application but is what your looking for.
http://www.spracingonline.com/store/...ool_Valve/3659
azn2nr is offline   Reply With Quote
Uppipe question for pros ASU_STi Newbies & FAQs 8 05-31-2009 01:41 AM
Shipping cost question for exhaust oilybirdy General Community 9 01-03-2006 09:55 PM
Question for the electrical engineers North Ursalia Off-Topic 12 11-07-2004 09:52 PM
Questions for us mechanical engineers balajc Off-Topic 9 05-21-2004 12:01 PM
Question for the Subaru engine builders: Cobb Tuning, B Spec USA, Rallispec, et al. Digital_Boy Normally Aspirated Powertrain 0 01-31-2001 03:13 AM
