Old 06-24-2010, 12:56 AM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default 2.2 abnormal temp
ok, I changed the HG recently but the temp still goes uo. Its an auto and I have noticed that it happens mostly when going slowly and uphill. any ideas? thanx
alejo is offline   Reply With Quote
Old 06-24-2010, 06:00 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
How is your coolant level? Has the thermostat ever been replaced?
Mike
GrimmSpeed is online now   Reply With Quote
Old 06-25-2010, 12:24 AM   #3
alejo
Member#: 170081
2004 2.5RS
blue
actually, it doesnīt have a thermostat. The coolant keeps "evaporating". I know my radiator is messed up, could THAT be my problem source?
Old 06-29-2010, 12:39 AM   #4
alejo
Member#: 170081
2004 2.5RS
blue
do you think the gearbox has anything to do?
Old 06-29-2010, 03:21 AM   #5
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Your post raises many questions
Why don't you have a thermostat?
How is your radiator messed up?
Evaporating. Please elaborate. If your coolant evaporates, how fast does it evaporate? Do you smell coolant in your vents while driving (recirculation off)? Do you see puddles where you park? Are any parts wet with coolant? If not, then you shouldn't be losing so much that fast.
Is your coolant properly topped off? Engine cold, heater turned all the way up, uncap radiator, start car, fill whenever the neck is low.
As far as I know, coolant goes nowhere near the tranny/gearbox. The ATF is cooled directly by the tranny cooler integrated into the radiator.
By just reading your post tho, it sounds like a bad waterpump.
Henry H is offline   Reply With Quote
Old 06-30-2010, 11:37 PM   #6
alejo
Member#: 170081
2004 2.5RS
blue
I didnīt come with a thermostat. Here in Honduras, we donīt tend to worry about it that much, so I havenīt bought one. The radiator has been repaired many times, and has some cells missing. So it appears to me it, it doesnīt cool properly. I canīt say for sure. It doesnīt smell like coolant whatsoever, and no puddles have appeared. And I havenīt tried toping it off with the heater on. the rest, I do pay attention to. I really hope it isnīt a bad waterpump, but tomorrow I will take it to the shop. I will keep you posted just in case.
2.5 EGT temps 06STi Engine Management & Tuning 4 04-04-2008 02:56 PM
Tuned 2.5 water temps screech Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-09-2006 01:06 AM
Run phase 1 dual port 2.2 heads on a phase 2 single port 2.2 block? wagonovsky Subaru Conversions 12 03-01-2006 10:27 AM
Why can't use 2.2 or 2.5 PH1 trans with 2.5 PH 2? rallynutdon Transmission (AT/MT) & Driveline 6 04-02-2003 06:01 PM
2.0, 2.2, 2.5 rbehny General Forum Archive 6 03-03-2001 12:50 AM
