Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-24-2010, 09:57 AM   #1
dadu007
Member#: 214970
Default A/C compressor fails to kick in with HOT weather
2000 Impreza L wagon 2.2L
A/C blows chiller air like a champ when the weather is below about 90 degrees F. Compressor engages/disengages normally while driving.
However, when the weather gets much warmer (HOT, when you REALLY need the A/C), the A/C will come on initially and cool for a few minutes, then the compressor will simply never re-engage again. (I verified this...opened the hood while blowing hot air with A/C switch on; compressor is not turning.)
Any ideas?
Thanks in advance.
dadu007 is offline   Reply With Quote
Old 06-28-2010, 10:00 AM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Perhaps you are at a loss of freon. There might be enough to have it work in the cooler conditions, but as it heats up there might not be enough charge to engage the clutch. If the A/C works at all other times I do not think the A/C itself might be broken, I would just check the charge, go to the local parts store and get a charging can WITH a gauge so you can see how much freon you actually have, and fill it accordingly.
Jessekrs123 is offline   Reply With Quote
When is squirrel evolution going to kick in? Reciprocity Off-Topic 18 08-21-2009 06:12 PM
When's my rev limiter supposed to kick in?? mxpro252 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-23-2009 09:22 PM
My one chance to kick in a door and I missed it ZMANNH25rs Off-Topic 23 12-22-2004 08:03 PM
Top 10 Celebrities you'd like to kick in the shin. donjuan Off-Topic 47 09-07-2004 02:56 PM
Guy at my school buggs out and attemps to kick butt with a baseball bat at 3:30AM kevinsUBARU Off-Topic 11 12-11-2003 08:51 PM
